Like Tree1Likes
Sirio engines thread
Old 10-14-2004 | 09:51 AM
  #646
gentleman81's Avatar
does the mid range needle play a important part in the motors temp, and the clutch engage point?
gentleman81 is offline
Old 10-14-2004 | 10:01 AM
  #647
afm's Avatar
afm
Originally posted by gentleman81
its a small parking lot track with a 150 ft straight way and about 300- 400 total track distance, i am running odonnel 20percent , a rdlogics turbo 2 pipe and ofna turbo plug. track temps were about 70-80deg last race, i race one race all day at about 200deg but it was hotter that day. how much does the temp effect how that motor will run hot? mtx3
Is that OFNA turbo plug equivalent to Novarossi C7TGF??? Because that is the one you should be using.
What gearing do you have??? With such a small track you should be geared very low to make that Sirio get on power. If you have 1.0 module gears, use 15/48 on first gear and 19/44 on second gear.
AFM
afm is offline
Old 10-14-2004 | 10:06 AM
  #648
the plug is a 51006 part number on it and it runs good never flames out or floods really, i dont know what its is equal to. i do have a hpi plug which i have heard are made by novarossi or atleast are very close, it is a cold-r8 (p/n 1508) do u thing they are the problem
i found these plugs are they the same it doesnt have the G in the part number?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old 10-14-2004 | 10:08 AM
  #649
i have the stock gearing which is 47/43 and 16/20 but i want to go to the .8 gears with a 22/58 28/52 or something close, is that wise?
Old 10-14-2004 | 10:59 AM
  #650
afm's Avatar
afm
[B..........................i found these plugs are they the same it doesnt have the G in the part number?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW [/B]
Yeah get those, they are the same heat range, only diff is they are not gold plated.
AFM
afm is offline
Old 10-14-2004 | 11:05 AM
  #651
afm's Avatar
afm
No, you are to long geared for such a small track. If you want to go to 0.8 modules go to 20/60 on firts gear and 25/54 on second gear. But I think you are still going to be long. I would stay on 1.0 modules and go to 15/48 and 19/44 and if you are to short you can allways put back ypur stock spurs 47/43 and leave the new 15/19 pinions.
AFM
afm is offline
Old 10-14-2004 | 11:57 AM
  #652
so what u are saying is that i am geared so that i wont hit my top speed on this small track
Old 10-14-2004 | 01:45 PM
  #653
afm's Avatar
afm
Yes, you are udergeared and you are not using the Sirio's power band effectively.
Check my car's setting a couple of posts back, and my track is about 1,000 ft long, and the main straight is about 200ft long, and I'm geared to the shortest second gear possible with 0.8 module (25/54).
AFM
afm is offline
Old 10-14-2004 | 01:58 PM
  #654
so since u run a mtx3 and a evo 2 your recomendation with be worth gold, but on the 1.0 gears and the 0.8 gears which do u like? i see that the mugen drivers use the .8
my total track size should be more like 500-700 feet i geuss but still i need to get up to speed which i am not the current time. do u know what the stock r40 and g4 gearing is? those are my major competition at the track?
Old 10-14-2004 | 02:21 PM
  #655
afm's Avatar
afm
Actually the 0.8 modules allow you to make finer steps in gearing, but they have limits when you need shorter gearing. The 1.0 modules make bigger steps between gears, but allow you to get shorter gearings, which would be more adecuate for your track conditions.
The reason top drivers from Mugen use the 0.8 modules is because most top level competition is done over large flowing tracks, and they make better use of the larger gearing possibilties.
The other technological reason is that 0.8 modules are a little bit smaller, so they give you a tad more acceleration because there is less centrifugal mass to move, but that isn't noticeable but by the best pros of the hobby.
The use of one module system over the other depends if you can build your gearing equally with both systems, than I'd go with 0.8 modules, but if you can't get the right gearing with them you must go with 1.0 modules.
AFM
afm is offline
Old 10-14-2004 | 02:29 PM
  #656
so u should try the .8 20/60 and 25/54 for my smaller track
i was noticing that to get my top speed i was almost out of track and into the corner at my track, this should help alot, do u know of a gearing manual or guide i would love to be able to get a couple sets and kow what type of reaction to look for instead of trying blind.
Old 10-14-2004 | 03:32 PM
  #657
afm's Avatar
afm
No, I think that is still to long on 0.8 module for your track, and those are the shortest gearings you'll get with 0.8 module:
20/60 gives you 7.579 final gear ratio on first speed
25/54 gives you 5.457 final gear ratio on second speed
If you go to 1.0 modules, you can get:
15/48 gives you 8.084 final gear ratio on first speed
19/44 gives you 5.850 final gear ratio on second speed
15/47 gives you 7.916 final gear ratio on first speed
19/43 gives you 5.717 final gear ratio on second speed
15/46 gives you 7.747 final gear ratio on first speed
19/42 gives you 5.584 finalgear ratio on second speed
16/48 gives you 7.579 final gear ratio on first speed
20/44 gives you 5.558 final gear ratio on second speed
Right now you have:
16/47 gives you 7.421 final gear ratio on first speed
20/43 gives you 5.432 final gear ratio on second speed
Conclusion: you have 4 shorter gearing combination options on 1.0 modules than what you currently have right now.
Time for experimenting my friend
AFM
afm is offline
Old 10-14-2004 | 07:30 PM
  #658
thanks for the help, unfortunatly the season is coming to an end at my local track i might have to travel to race.
Old 10-16-2004 | 03:32 PM
  #659
afm's Avatar
afm
CONGRATULATIONS TO SIRIO
FIRST 200MM WORLD CHAMPION.....WHAT A PERFORMANCE SHOW THEY'VE PUT ON THE WORLDS...EIGHT CARS ON THE FINAL
100% EFFECTIVITY....FASTEST LAPS......ˇˇˇˇWOW!!!!
1.-ADRIEN BERTIN
2.-TAKAAKI SHIMO
3.-CHRIS TOSOLINI
KEEP UP THE GOOD WORK......
AFM
afm is offline
Old 10-18-2004 | 10:17 AM
  #660
XTREMERCHOBBIES's Avatar
Arrow powerband
how does the powerband differ between the new sirio evo2(5-port) compared to the old sirio aac(5-port) engine? just a Q
XTREMERCHOBBIES is offline
