Like Tree1Likes
Sirio engines thread
Old 10-30-2007 | 04:19 AM
  #2161
Roelof's Avatar
Originally Posted by M7H
If they had only Patented there CENtrifugal To AXial clutch.....
And they can not because they copied it again from a motorcycle.....
Roelof is offline
Old 10-30-2007 | 05:02 AM
  #2162
M7H's Avatar
M7H
I actually was just thinking something like that.
It offcourse could have been that this system was already existing somewhere.....
M7H is offline
Old 11-03-2007 | 01:09 AM
  #2163
Grassy's Avatar
For everyone in Australia kelletts hobbies/ace hobbies now have the new .12EVO4 and sirio 7 plugs which are now marked.
Grassy is offline
Old 11-04-2007 | 05:02 PM
  #2164
doc56's Avatar
is there anyone familier with the sirio EVO4 tuning setup? i've tried mine and it seemed the power is not as satifying as the EVO3 STI. Any advice on the clutch tuning for this EVO4. I've tried the same clutch setup as the EVO3STI but the engine became lag, then i tried to increase the clutch engagement (tighten more) and it increased a little but runtime was effected. I've even tried various clutch gap but still the same. Can anyone suggest me the needle setting or power setting for his engine. TQVM
doc56 is offline
Old 11-08-2007 | 08:38 PM
  #2165
doc56's Avatar
is there anyone familier with the sirio EVO4 tuning setup? Please advice...TQVM
doc56 is offline
Old 11-11-2007 | 04:29 PM
  #2166
Anyone in the US have the Evo4 yet? I am looking to pick one of these up as soon as I see them in the U.S.
kaotickc is offline
Old 11-15-2007 | 04:28 PM
  #2167
GMartinez's Avatar
Got mine from Italy they are not available in the U.S. yet hopefully before the year ends
GMartinez is offline
Old 11-16-2007 | 03:55 PM
  #2168
GMartinez's Avatar
Sneaky pm I got my Evo 4 from www.capricornrc.com
Old 11-18-2007 | 08:05 PM
  #2169
doc56's Avatar
have u tested the engine? how the clutch setup? is it similiar to the Evo3STI? how the power? I hope it is the same because it uses the STI conrods, crankshaft, and the design of the piston and sleeve looked similiar to the Evo3STI
doc56 is offline
Old 11-19-2007 | 01:06 PM
  #2170
rmdhawaii's Avatar
On my Evo3 STI, the plug seems to be leaking. This really sucks. Is it just me or is the button head material too soft?
rmdhawaii is offline
Old 11-19-2007 | 01:11 PM
  #2171
Haven't heard about that problem. I assume you are using Sirio glowplugs.
Scott Fisher is offline
Old 11-19-2007 | 03:11 PM
  #2172
GMartinez's Avatar
Evo 4 Piston & sleeve looks identical to the 3 I have not inspected the crankshaft yet & have not had a chance to break it in as for the power I've seen Toso running it for a couple of races & there's no doubt that it is fast
as for the clutch it is way lighter than the standard RRR system & will be getting it ready for my next race so I will be able to give you more info but the clutch is really sweet
Old 11-19-2007 | 03:14 PM
  #2173
GMartinez's Avatar
Been running the Sirio for 2 years now & have not come across this issue
Old 11-19-2007 | 05:36 PM
  #2174
doc56's Avatar
Never experienced this before. Are u using the correct sirio plugs? or have the threads on the plugs or at the turbo head been compromised? probably u screwed it (plug) in to fast without matching the thread correctly, and damaged the thread on the turbo heads?
doc56 is offline
Old 11-19-2007 | 05:37 PM
  #2175
Default sirio kanai evo2 crankshaft
Does anyone have a crank for a sirio kanai evo2 motor, or know of any other crank that works in this motor.
scott74dog is offline
