Like Tree3Likes
Tamiya TRF415
Old 07-16-2007 | 09:09 PM
  #18871
Xanavi_R34's Avatar
Originally Posted by maxepower
I would like to add to this conversation by saying if your going to use steel screws, use the stainless steel screws. The kit screws, I believe are a little softer than stainless and the weight is about the same. There are many aftermarket companies that make them.
I also would add if your going to do races that there are weight limits then stick with stainless steel but if you run where there is no minimum weight requirements then getting the car as light as you can is like free horsepower.
I would take advantage of any performance gains, since the screws have to be in the chassis anyway, why not spend a few more dollars to make the car lighter and quicker coming in and out of the corners? The average racer probably can't feel the difference but you'll have the potential of saving a few tenths on the lap times for sure!
Just my 2$
okay sir, thanks for the info about ti and steel screws... will see what I can do...
Xanavi_R34 is offline
Old 07-16-2007 | 10:11 PM
  #18872
I feel that the cars should be as light as possible.And the weights added can be used for tuning purposes.
Ben.C is offline
Old 07-17-2007 | 01:50 AM
  #18873
TryHard's Avatar
Agreed. I've been using the Ti/Aluminium screw kit's from RC Champ for ages
1) the look great (all anodized blue on the top )
2) they are about as light as you can go (unless you go full alu, which for high load areas is a no-no).
Bascially, the underside of car is Ti, and the top in the blue alu. What it does mean is that any weight I take out of the car can be put back in ballast... which can a) lower the cg and b) give another tuning option
If you take a 10g out from the topo of the car... and place it down on the chassis... instant improvement. Obviously, I doubt anyone but the best can notice a difference, but there still the psycological advantage of having done it....
regards
Ed
TryHard is online now
Old 07-17-2007 | 04:30 AM
  #18874
Burlap's Avatar
I just run Ti screws everywhere since they are relatively cheap from RC Champ. Even the Mini runs them
Burlap is offline
Old 07-17-2007 | 04:35 AM
  #18875
rampal's Avatar
another vote for champ blue aluminum/titanium screw sets.
rampal is offline
Old 07-17-2007 | 11:36 AM
  #18876
PizzaDude's Avatar
Burlap,
Any idea of the weight improvement as opposed to the stock (kit) screws in the mini?
PizzaDude is offline
Old 07-17-2007 | 04:41 PM
  #18877
Burlap's Avatar
Originally Posted by PizzaDude
Burlap,
There is probably bugger all, and I am not doing it from a performance stance. I just hate phillips head screws, so replaced as many as I could in the Mini with the hex head titanium screws.
Burlap is offline
Old 07-17-2007 | 04:57 PM
  #18878
TryHard's Avatar
hey guys,
Forgot to mention, my site is back up and running. Been down for a few weeks whilst I sorted out a server provider issue (my fault).
Added a couple of my more recent setups, and Corey Lewis' from RRoC this year.
Also working on a better method for searching the setups... I have some ideas in the pipeline. Never know..I may even get a chance to add some newer pictures too!
regards
Ed
(p.s. for those who don't know... link in the sig )
Old 07-19-2007 | 05:00 AM
  #18879
belgianchamp's Avatar
Hello Eirik,
I saw in the entry list of the Euros 2007(France Montbrison) that you are participate.Im also driving the Euros for team Belgium and hope to get a nice result...last year i was 62th...not bad
Do you know something about the track or have a detailed setup that i can start with?Maybe u spotted or heard something from Victor?
Il see u over there!
belgianchamp is offline
Old 07-19-2007 | 01:02 PM
  #18880
Eirik's Avatar
Originally Posted by belgianchamp
Hello Eirik,
Hello,
Unfortnately I will not make it to the euros this year, just some bad planning actually
I have not talked to Viktor in some time, but I will see what I can find out for you.
Good luck mister!
Eirik
Eirik is offline
Old 07-19-2007 | 03:23 PM
  #18881
Aaah no luck dudeIt should be great if i had good starting setup...the first thing i will do is go to team tamiya and give my eye a good shot, you will be surprised what you can see from all the topdrivers(some little tricks that make a big difference)and try it out myselfeven im not a topdriver
Go Marc and Victor and all the Tamiya drivers!
Thx men!
Old 07-20-2007 | 11:28 AM
  #18882
Toughbeard's Avatar
regards
Ed
Agreed
My car weights 1427 ready to race w/o transponder (18 - 20 grams). I am not that good to feel the difference of a 1500 flat car vs a ballast balanced 1500gr car but I sure see the faces of the other drivers when my car comes out 1508 with transponder. It is a psycological pressure on them, which I hope will force them in to error
Toughbeard is offline
Old 07-21-2007 | 07:25 AM
  #18883
question
Need I little help guys I just a TRF415 and have a lot of question
1 What the tyranny ratio
2 Part number for a ball diff for the front
3 The place to buy parts in the US
4 Gearing for 13.5
5 Can you use any spur gear on it beside the Tamiya
rdallier is offline
Old 07-21-2007 | 07:40 AM
  #18884
sosidge's Avatar
Tyranny ratio = Police brutality to strike fear into citizens/Creating god myth about leader
But it also depends on the pulleys you use.
sosidge is offline
Old 07-21-2007 | 12:14 PM
  #18885
Tek Nickal's Avatar
4 Gearing for 13.5
1. If your pulleys are black colored, your internal ratio is probably 2.1875.
If your pulleys are white colored, your internal ratio is probably 2.25.
2. The part number for the ball diff is #53921. It does not come with a diff pulley, you need to buy that separately.
3. Try your local hobby shop...
4. Depends what track your going to run the 13.5 and how large the track is.
5. You can use any standard spur gear I believe. The Tamiya spur gears are a metric pitch, 0.4 module. Although 64 pitch pinions work fine on it.
Tek Nickal is offline
