Old 02-01-2007, 06:07 PM   #17371
Originally Posted by buboy28
yup you are right its the wheel axles that are bent already ordered 2 pairs might have to take out the front also before anything happens thanks for the help guys
The lightweight ones are for pure performace... The 1st time I built my MRE, I immediately kept those and got steel ones for my MRE before these things happen.
Great that you've found out your problem.
Ben.C is offline   Reply With Quote
Old 02-01-2007, 06:24 PM   #17372
dbmartin's Avatar
Originally Posted by hierog
does anybody know if the 415 spool drive cups will work in the MRE spool?
thanks
vic
they have to be modified slightly to work. but they will get the job done, would reccomend getting the replacements for the mre.
has anyone had any issues w/ chassis tweak? by this I mean, I set the ride height correctly front to rear, but when i measure the chassis height in the middle of the chassis, the electronics side hangs down about a mm lower than the batterside, specifically where the servo mounts.
I loosened all of the screws and flattened the chassis on my tweak board, then re-tightened everything back up, but no help.
short of stripping it down and checking the chassis, has anyone had this issue before?
Thanks.
btw, this car rocks!
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 02-01-2007, 06:51 PM   #17373
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
yup thanks for the help will install the steel wheel axle tonight and run the car tommorrow will try to join club race tommorow using 27T motor(Stock)
buboy28 is offline   Reply With Quote
Old 02-01-2007, 07:03 PM   #17374
hierog's Avatar
Originally Posted by LBSR415
yes but the steel ta05 ones work better
thanks for the quick answers guys! you mean the metal ones from the ta05?
vic
hierog is offline   Reply With Quote
Old 02-02-2007, 01:16 AM   #17375
TryHard's Avatar
Personally (and this is just me), I prefer to make sure the tweak of the car is perfect, so get it set best on the tweak board. Then I'll set the ride height, by adjusting the collars on both sides equally. If the ride height is off a bit (say .5mm difference) I don't worry about it, as long as everything is level on the tweak board. Equal pressures on the wheels is more important than having a level ride height, IMO.
Also, I only ever measure the chassis height at the very front and at the very rear, never in the middle... mainly as I like to run a bit of rake.
IF you still worried, strip the car down fully, and check the chassis plate isn't warped... I tend to find I don't need much difference in shock collar adjustment on the MRE.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 02-02-2007, 05:37 AM   #17376
LBSR415's Avatar
vic
yep,,,work like a charm and the last ones you'll ever buy
Team OHP
Razor Graphix
East Coast R/C
Pantheon Motorsports
These fish,,,are frozen.
LBSR415 is offline   Reply With Quote
Old 02-02-2007, 09:08 PM   #17377
Send a message via AIM to GuyIsDamGood
Hey TRF 415 MSX Guys. I have a TB Evo 5 and I`ll like to know if Item # 53938 - Aluminum Rear Uprights($51.00) is set at 0-Degrees?
-The TB Evo 5 comes with Item # 53807 - 0-Degree Rear Uprights($51.00).
I would like to get those Rear Uprights; but only if they`re set at 0-Degrees.
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 02-02-2007, 09:12 PM   #17378
hierog's Avatar
why do you want to change to a from a 0 degree hub to a different 0 degree hub?
Old 02-02-2007, 09:19 PM   #17379
I`ve read that 53938 - Rear Upright has the Bearing set lower and it makes the kit/car turn better on high - traction tracks. . . . .It`s a TRF Thing.....Ha Ha!
Take Care
Old 02-02-2007, 09:23 PM   #17380
Trader Rating: 15 (100%+)
Default ride height difference
Check your shock towers ..there is enough slop up and down to cause 1mm .Just loosen and either pull up or push down and tighten.Might help you.
AARON YOUNG is offline   Reply With Quote
Old 02-02-2007, 09:26 PM   #17381
Default axles
I run the old long 415 axles and shim out the slop.
Old 02-02-2007, 09:26 PM   #17382
hierog's Avatar
Take Care
hmm, didn't know that. tamiya's site doesn't specify that it is 0 degree, however it does show a 0 on the hub
vic
Old 02-02-2007, 09:35 PM   #17383
I thought the TRF 415 MSX Marc Rheinard Edition Kit comes with 53938? Anyone out here have the Marc Rheinard?
-The Rear Uprights have H 0 on it. . . . .What does that mean?
Take Care
Old 02-02-2007, 10:18 PM   #17384
I`ve read that a few of you guys say that the Aluminum Wheel Axles(Item # 53939 - $23.50 for 2) will bend.....Wow.
-I`ve seen those Axles; they`re thick(the exact same) as the Steel Axles(Item # 51094).
- -Did anyone crash with those axles on their kit/car? I think that`s the only way they`ll bend.....?. . . . .Tell me what`s up.
I`m thinking about getting those Aluminum Wheel Axles for My TB Evo 5; you guys could save me $47.00.....Thanks.
Take Care
Old 02-03-2007, 02:31 AM   #17385
Stein Tumert's Avatar
Take Care
The alu axles does not take much beating, I would not get them.... unless you never hit something
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
