Tamiya TRF415
Milky Blue Springs
To everyone who bought the Milky Blue Spring sets:
The white spring in the Milky Blue Spring sets is different from the White spring that comes with the regular set.
Tamiya removed 1/2 a coil, so now instead of the original white 15.27 lb/in spring, it's now stiffer. That's a good thing since I always thought that the white spring was too close in rating to the blue 14.08 lb/in spring.
I don't know how much stiffer. I no longer have access to the spring tested that I had at my old job.
The rest of the springs (blue, yellow and red) are the same.
Originally Posted by linger
Where can I get the parts to piece together an MRE spool? I can't seem to find them anywhere??!!??
Vellrip's eBay Store - Singapore
I normally get my parts for my MRE from him (shipping may be a bit pricey though). He has the kit parts & also the parts to build the spool. The only thing he doesn't have for the spool are the pins to hold in place the delrin cups/outdrives.
R/C Tech Elite Member
Originally Posted by JRRobiso
Linger try this guy:
I'm a bit sus on Vellrip at the moment, first order all good, second order, 3 weeks later and nothing. Had to file a Paypal complaint to even get a response.
Pity, I want my bits!
I'm Spoolish!
Originally Posted by veecee
Just a cheapie from Shooters as I'm still toying with a spool.
Originally Posted by AARON YOUNG
LIng king dong ,
Originally Posted by TRF415boy
That could be your problem, spools with delrin outdrives provide a much better turn in and mid corner steering than ones with steel/aluminium outdrives.
Originally Posted by maxepower
Not sure what that is made of but if it has a lot of rotating mass,i.e. steel, heavy gauge aluminum, this tends to take away steering. If this is the case then there are a few ways to increase steering coming into the corners. A quick fix would be increasing the rear droop which will transfer weight to the front tires on entering a corner. You can also add .5 mm shim under the rear block in the front. This will also transfer weight to the front. If all else fails get the MRE spool and it will give you the steering you had with the one-way, maybe even more!
Yeh it's a complete alum unit. I'll try and get hold of a spool with Delrin cups. What does everyone think of the Titanium Racing spool - not the latest ones just released?
Charles
Hi:
Can someone confirm that 53919 alum diff joint - TA05 is the same that 9804249 alum diff joint L/R for the MSXX???
thanks,
al
thanks,
al
Nope, it aint!
Sorry!
Sorry!
So you have to purchase 9804249 sepratly as well as 53919?
thanks
al
