Spektrum
#1922
Originally Posted by EAMotorsports
Thats what the stock receiver that binded to my module did. If you touch the receiver with your finger the light goes out as well? But you can pick the car up, shake it, smack it and throw it and it still works fine. I think its static doing it as mine would run ok for a few corners and then go nuts. Then regain control and loose it again a few corners later. That may not be it but I'd be curious if yours cutts off if you touch it with your finger like mine did.
EA
EA
#1923
Originally Posted by DORIFT
Hi all... Sorry if this has been covered...
I recently purchased the Spektrum system for my KO Helio. It is the PRO Version. However I am still facing problems. The car would glitch and sometimes loose control completely. It only happens to certain parts of the track and sometimes it is completely fine, and next lap it is completely disasterous.
I am using KO VFS-1 ESC, with KO Servo. Do I need to adjust the ESC as my friend pointed out to me that I need to increase the Voltage in the ESC to 4.0V and it may solve the problem.
I am even running the Spektrum Capacitor but still no luck.
Please advice.
Thank you.
Please advice.
Thank you.
#1924
Originally Posted by rocketron
I have been using the equiptment your mentioning for a long time with Spektrum. Two things you should check with the first being to ensure you have the BEC set to 4.0 volts, and the second "glitching" is more than likely the connector in the receiver. I had what an intermitent "glitch" at the last carpet nationals and after a lot of frustration found it was the connector from the esc. After tightening the connector (temporary) all worked just fine, and I then replaced the connector and am still using the same equiptment now and have not had a single problem. It was frustrating until this connector was discovered.
Just need to borrow my mates controller next time. I will also check to see if all connectors are looking sweet. Thanks again.
#1925
I went back to my LHS today with my micro receiver to see if they could get it to bind but no luck. So we called Horizon and got a Spektrum tech on the phone. After explaining the problem he stated that it must be some internal problem and advised us to send it back. I hope I have better luck with the replacement receiver.
#1926
I just purchased a brand new Micro Receiver and to my surprise it will not bind. My other micro binds just fine but I get a glitch twice during a run. Where can I go to get these serviced under warranty?
#1927
Give Horizon Hobby a call and let them know what the problem is. They will be able to advise you where to send it.
contact Horizon
contact Horizon
#1932
I've got one of the older bigger spektrum rx's running 1/12 with a lrp qc2 and a capacitor. Only problem I have is if I smack a board it needs turned off and back on to restart everything. Can I send in just my rx and get it upgraded to get rid of this problem?
#1933
#1935
I would still suggest sending the receiver in and having the firmware updated. Re-routing the module antenna will help, but the new firmware provides a fix for the electrostatic discharge issue as well.
