Mugen MTX-4
Old 01-02-2006 | 02:39 PM
  #2926
Racing4Evo's Avatar
Originally Posted by Corse-R
How you stripped a solid plastic piece that goes solidly attached to the outdrives??? Maybe some gorilla tried to twist each wheel on the axle in different directions?
It does strip out easily especially if you get air born, the shock of the landing will deform the plastic. That's why there was a metal altenative on the V-One RRR.
Soon though there will be an even better alternative from Skyline RC.
Racing4Evo is offline
Old 01-02-2006 | 02:51 PM
  #2927
TexasRacer's Avatar
Yea they strip really easy, I think that solid axle lasted a whole 2 weeks of racing haha! Also yea at our track the cars get air born right Mgreen?
TexasRacer is offline
Old 01-02-2006 | 02:56 PM
  #2928
Corse-R's Avatar
Hehehe.... the same but multiplied by many is what happens on a 1/8 scale if you got airborne at full throttle.... twisted dogbones and munched outdrives... expensive repair if you do it another time with a solid core, only god may know what you can blast if on another time you go airborne.
Corse-R is offline
Old 01-02-2006 | 04:02 PM
  #2929
Talking
Yes it was a bad idea to run without the engine brace. I did not think it would make that big of a difference. But as of now, the engine brace is back on.
mgreen is offline
Old 01-02-2006 | 04:07 PM
  #2930
protc3's Avatar
hey guys,i got my car all together now awaiting a setup.can someone post or PM me a good starting point for a high grip kinda tight track?the turns are flowing but still kinda tight.any help would be greatly appreciated.
protc3 is offline
Old 01-02-2006 | 04:11 PM
  #2931
ogreasurada's Avatar
I think the stock set up is a very nice starting point already~
ogreasurada is offline
Old 01-02-2006 | 04:19 PM
  #2932
protc3's Avatar
ok,thanks buddy.
protc3 is offline
Old 01-02-2006 | 06:29 PM
  #2933
rcfoolz's Avatar
Protc3.....call me, I have a setup for the track without the steering being so twitchy like the way I drive my car..
rcfoolz is offline
Old 01-02-2006 | 08:40 PM
  #2934
Tag's Avatar
Tag
hello, could someone explain to me the effect of using lower mount housing in the rear lower arm as opposed to middle ones ? thanks
Tag is offline
Old 01-02-2006 | 09:25 PM
  #2935
jca2000au's Avatar
Hi... Tag
From my understanding:
Low: the suspension arms are lower from the ground, for high traction track.
Med: the suspension arms are in the middle, for medium traction.
High: the suspension arms are stay higher from the ground so the car can have more roll, for low traction track.
But I could be wrong.
jca2000au is offline
Old 01-02-2006 | 09:27 PM
  #2936
asw7576's Avatar
Rear block position :
A = lowest = more body roll, more rear grip, suitable for low grip track, bumpy or dusty track.
B = middle = neutral
C = highest = less body roll, suitable for high traction track or high grip technical track.
Ackerman steering block :
A = aggressive steering, good for technical track
B = neutral
C = smoothest steering, good for sweeper / high speed.
Rear upright (upper link) position :
More angle = more grip, more side bite, more body roll, suitable for low grip
Less angle = less grip, less side bite, less body roll, suitable for high grip.
asw7576 is offline
Old 01-02-2006 | 09:34 PM
  #2937
Tag's Avatar
Tag
thanks for the help guys i guess i will start with the lowerest , i want to have as much rear traction as i can get,
Tag is offline
Old 01-02-2006 | 09:37 PM
  #2938
Tag's Avatar
Tag
jca2000au : i like your avatar even though "they" are making me dizzy
Tag is offline
Old 01-02-2006 | 09:41 PM
  #2939
MAVICXXX's Avatar
Originally Posted by mgreen
I love the car and how it handles but I kept on striping out the 2nd gear. I do not know what to do. I notice that the swaybar sort of touches the 2-speed housing. It happens about 2 minutes into a race. I'm not using the engine-brace so could it be flexing?
fren, me thought of that too lastime but it wasn't,well actually my case was the sway bar touching,better check on the 2nd gear housing wether t6he ring u mention is like 2mm wide or not?coz if its the clucth bell,u gona have like dented few spots due to the clucth movement,but i think yours is the same as mine. You can try to make the sway bar linkage bit longer and adjust your droop properly,actually it happens when its like airborne.
MAVICXXX is offline
  #2940
jca2000au's Avatar
If you are using A block = lowest. How can it be more body roll since the suspension arms are almost flat to the ground?
