JP engines
#451
Originally Posted by wendellc1
Where can I find Cyrul's method and what's heat cycling?
#452
Originally Posted by Hesky
this guys engine breakin method is well different to most, and I like his theory behind it. but I have a slight issue with opening the carburetor to full throttle and holding it there on a new engine that has mega pinch, I know the engine will be practically flooded with fuel and the rpm even at wot will be significantly low running that rich, but is it still safe to do it on a very tight engine?
#454
Originally Posted by daniz24
New line of JP Racing Special Engines...
#455
Originally Posted by Racing4Evo
Is that a .12 engine? It looks like a 5 port. Do you have any information or pictures of the 3 port? I am getting one soon and I don't want to get the older version.
#456
What do you mean by traditional breakin method? Be sure you warmed the engine first to get some working temperature before the WOT method.
by traditional I mean run the engine rich, not excessively to the point it nearly flames out and blip the throttle never exceeding half throttle for the 1st 6 tanks, I do the heat cycle b4 that of course. Basically just easy on the rpm initially.
yes, I'm just thinking about the excess stress on the conrod when the engine has a lot of pinch at tdc and is ran at WOT.
#457
hey gonzo, this is a rendering of a model jet engine I've just finished designing, even after playing around loads with powerful cad programs I still use paint, go figure
#459
I was able to ran 5 gallons yesterday. 2 tanks having the car idle on the starter box (factory setting at 190F) and 3 tanks at WOT at a very rich setting. One thing I am concern is the temp, using Josh's method, the engine ran cool at 120-135F at most. Before starting, I always bring the temp up to 150F, but even at WOT, the temp kept dropping. Does the extra fuel compensate for the low temp in this regard? Thanks.
#460
Its not a case of compensating, you want to get the engine to a reasonable running temperature so all components have expanded to what they would while racing. try wrapping the cooling head with aluminium foil to reduce the cooling heads efficiency.
#461
Broken in the engine at the track on Saturday. After the 14th tank, I leaned out the engine to 180F (still very rich), and all I can say is...holly &h!t!. This engine feels like it can take out my EVO3 at this temp! Question: Is it better to keep the temp at 180F for a while during practice (if yes, for how long) and raise it up to 220F for a race?
#462
#463
What Hesky said is good. It is always very recommended to keep your engine to cool down at least 30 minutes every 2-3 tanks of practice with approx 90% from it's optimum temperature. have a good race with JP Racing Engines.
#464
I ran the engine yesterday on the track and for some reasons, it didn't feel fast. I know my engine is still running rich at around 200F, but the power wasn't there. The pipe is spitting out a lot of smoke, but it is its 18-20th tank. Should it be fast by now? I still want to take it slow and run it for a couple more tanks at this temp. My friend's EVO3 was a lot faster at the track yesterday with a temp of around 220-230, so hopefully, I can catch up to him after my full break-in.
#465
1Likes
