Old 01-10-2005, 12:51 AM   #301
InitialD's Avatar
Originally posted by asw7576
Can you guarantee it will work ? I expect slower performance but not dead engine.
Of course it'll work !
Old 01-10-2005, 04:18 AM   #302
asw7576's Avatar
Originally posted by daniz24
Yes, you can just buy a plain NSR3/NSR5 piston sleeve set...
NSR or NS ( without R ) ?
I plan to experiment with it, ..... make it crazy fast Kondor style... he... he...
Dude, will you have O.S .18 TZ ( 2.25 HP ) in your shop ? ..... I'm not sure I can handle that , but I'm willing to drive it first. Must be overwhelming experience !
Old 01-10-2005, 09:13 AM   #303
Data's Avatar
Originally posted by InitialD
It'll still fit but the exhaust / intake numbers would not be the same...
just curious, why would the intake number be different if just changing the piston and sleeve ?
Data is offline   Reply With Quote
Old 01-10-2005, 11:16 AM   #304
InitialD's Avatar
You're right Data. Thanks for the correction. The intake would depend on the crankshaft which is not changed in this case. What I meant to say was the exhaust / transfer numbers would not be the same...
Old 01-25-2005, 11:55 PM   #305
asw7576's Avatar
I read exploded view for NSR12 S3 & S5, JP FX3 & FX5, NS15 S5.
These novarossi parts give your FX another chance to live and serve. Here is the summary for interchangeable parts:
Parts that can be use for ALL of them are :
07601 microcasted conrod
16602 rear bearing
17006 front bearing
10608 carburator complete set
In addition to that, NSR12 S3 and JP FX3 parts are interchangeable :
08658 complete set piston, sleeve, conrod ( 3 ports )
15616 crankshaft
09626 crankcase
28605 alluminium button head for ignition chamber
NSR12 S5 and JP FX5 :
08659 complete set piston, sleeve, conrod ( 5 ports )
15615 crankshaft
09626 crankcase
I don't have information for cross use between NSR12 S5 to JP FX3, for examples 08659 complete set piston, sleeve, conrod ( 5 ports ) going into JP FX3.
Old 01-26-2005, 12:34 AM   #306
InitialD's Avatar
I believe the carbs on the .12 engine will fit on the small block .15 engines (NS15 S5) and vice versa. Just that the 10608 carb on the NS15 S5 engine is without the 3rd brass needle screw which is similar to the one that the JP FX engines have...
BTW, a 3 port engine will fit a 5 port sleeve and vice versa regardless of it being a Novarossi engine or a JP FX engine...
Old 01-26-2005, 12:52 PM   #307
asw7576's Avatar
Nice to know, thx D !!
When do you expect JP engines need overhaul ( piston, sleeve, conrod ) ? 4 gallon of fuels ? How about only conrod replacement after 4 gallon ? cheaper u know
Old 01-26-2005, 07:01 PM   #308
InitialD's Avatar
Depends on how you raced the engine... Check piston sleeve if the piston is able to overshoot the piston liner / sleeve. If you can do this with the piston sleeve out the crankcase with just your bare hands, then it's already time to retire it.
Secondly, to check compression, what people do is to crank the engine flywheel until the piston closes the exhaust port. Put a few drops of after run oil into the exhaust port of the crankcase so that the oil is trapped there at the exhaust port where the piston is blocking.
Then, try to crank the flywheel up to TDC slowly while observing if there are any bubbles coming out of the exhaust port because of the after run oil. If there are a lot of bubbles all the way when you crank up to TDC, then the piston sleeve has loss compression and does not have the required seal anymore. Of course, do this with the engine head and plug mounted.
Old 01-27-2005, 01:10 AM   #309
asw7576's Avatar
Thank D !!! I appreciate it, you are the best !!
Old 01-27-2005, 11:40 AM   #310
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
This info as I had said months ago actually tells me that why would you buy a stock JP Fx engine if you can find a Nova NSR engine for less money. If the bearings, rod, crank, piston, sleeve, carb, button and crankcase are the same part number, then they are the same engine. The bling is kinda nice, but why spend more money for exactly the same engine.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-27-2005, 01:02 PM   #311
asw7576's Avatar
JP FX vs NSR ?? are you kiddin ?
Old 01-27-2005, 04:41 PM   #312
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I agree that JP are rediculously overpriced. The performance advantage is not proportionate to the extra money. For 99% of the time the NSR is just as fast!
Racing4Evo is offline   Reply With Quote
Old 01-27-2005, 07:33 PM   #313
How can there be a performance advantage. They are the SAME. Only the tuning and maybe a little luck in terms of parts fitting will make one different from the other. The only thing I can thing of is if my memory serves me correctly, the NSR has a 9 fin head and the JP has an 11 fin head. This will make a difference to those that use stock cylinder heads.
Old 01-27-2005, 08:35 PM   #314
InitialD's Avatar
Ummm, stock JP FX has the same port timings on the sleeve and the crankshaft as an NSR?
But about the heatsink thingy, I never had a problem using 9 fin on my RRL5. Even on a hot 30 odd degree Celsius tropical climate.
Old 01-27-2005, 08:44 PM   #315
asw7576's Avatar
FYI : Good news for you.........the latest NSR12S5 engines have 11 fins too ( I saw it at my LHS which imported novarossi recently ).
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
