Mini-96 World Challenge
#2386
Narrow
Date-7/24
Location- California
Race Time-325.10
Fastest Lap-4.01
Chassis-MR-03 EVO
Body-911
Wheelbase-90mm
Tires- PN medium radial. F PN KS medium slick
Motor-3500KV
Batteries- PN 750
Date-7/24
Race Time-325.10
Fastest Lap-4.01
Chassis-MR-03 EVO
Body-911
Wheelbase-90mm
Motor-3500KV
Batteries- PN 750
#2387
2wd open
Date-7/21/24
Race Time-276.27
Fastest Lap-3.30
Chassis GLR-GT
Body- Jomurema with lean roof
Wheelbase-98mm
Rear PN Marka 10
Front PN Med slick
Motor- GL 3500KV
Batteries- 2S lipo
Date-7/21/24
Race Time-276.27
Fastest Lap-3.30
Chassis GLR-GT
Wheelbase-98mm
Rear PN Marka 10
Front PN Med slick
Motor- GL 3500KV
Batteries- 2S lipo
#2389
Porsche cup
Date 6//24
Race Time-306.30
Fastest Lap-3.73
Chassis-Kyosho
Body- 911 GT1
Wheelbase-90mm
Rear Marka Marka 10
Front PN KSM soft slick
Motor-PN3500kv
Batteries- Orion
T plate white fiberglass
Front springs PN purple
Built a new legal Porsche cup car. This was the first run on it so should be fast with some tuning.
Date 6//24
Race Time-306.30
Fastest Lap-3.73
Chassis-Kyosho
Body- 911 GT1
Wheelbase-90mm
Rear Marka Marka 10
Motor-PN3500kv
Batteries- Orion
#2390
Class- BoxStock
Date-07/31/2024
Location- Central Texas
Race Time- 6:02.828 /362.828 seconds
Fastest Lap- 4.239 seconds
Chassis- MR03
Body-Audi R8
Wheelbase- 98mm
Wheels- F- PN BBS +1mmN / R-PN BBS +1mmW
Tires- F- PN KS L.H. Med / R- PN KS-M Radial Soft
Motor- Stock
Batteries- HiTec 750hv
Front Springs- green
T-Plate- PN #4
Motor Mount- MM
Dampener (If applicable)- top shock
Dampener Fluid (If applicable)- 15k grease
Gearing- 7t
Notes- Car running very well, my back not so good, so my times might show it. Just took some meds and will run before midnight.
Ran 75 laps and it and I need work in box stock. The power difference between BoxStock and all my Brushless chassis gives me fits with my timing into corners.
Date-07/31/2024
Chassis- MR03
Body-Audi R8
Wheelbase- 98mm
Motor- Stock
T-Plate- PN #4
Motor Mount- MM
Gearing- 7t
#2391
Class- Stock
Date-07/31/2024
Race Time- 6:06.761/ 366.761 seconds
Fastest Lap- 4.133 seconds
Chassis- PN 2.5W
Body- McLaren 12C- lexan windows
Wheelbase- 98mm
Wheels- F- PN 19mm White Dish +1mm / R-20mm PN BBS +2mm
Tires- F- Marka V14F25LP / R- PN KS-M Radial Soft
Motor- PN 3500kv
Front Springs- Purple
T-Plate- PN #4 Carbon
Motor Mount- PN Multi-Mount
Dampener (If applicable)- PN DDS Carbon Gold top/Purple bottom springs
Dampener Fluid (If applicable)- dry
Gearing- 12/53 PN Gear Diff
Notes- Just starting out on the Marka fronts. So far so good. Just built this from MR03, and it is good, but needs a bit of tweaking to be perfect. The car has half of the steering compared to my ProStock chassis. Main difference is front tires. I seem to be waiting on the car to turn mid corner to exit, before I can get on the throttle. Hand wasn't much better after a short break, so consistency wasn't very good! I should have ran a full 75 lap run mid month, as I was much better then!
Update: the patch on the front fender is holding strong, thanks Plastic Surgery!
Date-07/31/2024
Chassis- PN 2.5W
Wheelbase- 98mm
Motor- PN 3500kv
#2392
Class- ProStock
Date-07/31/2024
Race Time- 5:42.721 / 342.721seconds
Fastest Lap- 3.975 seconds
Chassis- PN 2.5W
Body- Jomurema- Lexan Window and Wing
Wheelbase- 98mm
Wheels- F- PN BBS N+2mm / R- PN BBS W+2mm
Tires- F- PN KS-M LH Med / R- PN KS-M Radial Soft
Motor- Rocket 5500kv
Front Springs- Green
Motor Mount- PN V3 94/98mm
Dampener (If applicable)- PN DDS Carbon Green bottom/Purple top springs
Gearing- 11/54 PN Ball Diff
Notes- Car is dang near perfect! It has better times in it with a better driver. Car is super fast and on rails! Throttle is at 50% with new HiTec 750 batteries and the Rocket 5500kv.
Date-07/31/2024
Chassis- PN 2.5W
Wheelbase- 98mm
#2393
Class- Porsche 911
Date-07/31/2024
Race Time- 5:59.886 / 359.886 seconds
Fastest Lap- 4.125 seconds
Chassis- MR03
Body- 911
Wheelbase- 90mm
Wheels- F- PN 20mm BBS N+1mm / R- PN BBS W+1mm
Tires- F- PN KS-M LH Med Glued sidewall/ R- PN KS-M LH Soft Slicks
Motor- PN 3500kv
T-Plate- Nexx #4 Carbon
Motor Mount- Nexx RM
Notes- Glued the sidewalls of the front tires, and NO more traction roll! I can push it almost as hard as I want. Hope my back will allow me to get some clean laps!
Ran 75 laps and was doing ok, but it fell a part a bit mid race. The car has a sub 4 second lap in it after gluing the sidewalls, but my nerves had my hand pretty numb half way through.
Date-07/31/2024
Chassis- MR03
Body- 911
Wheelbase- 90mm
Motor- PN 3500kv
#2394
Class- Box Stock
Date- 07/29/2024
Location- Saskatoon, SK Canada
Race Time- 329.1
Fastest Lap- 4.08 seconds
Chassis- MR-03
Body- McLaren P1 GTR
Wheelbase- 98mm
Tires: F - PN KS Slick 22.8mm R- Marka V1R10 trued flat
Motor- Stock
Batteries- Silver Horse RC 800
Front Springs- Kyosho Red
T-Plate- PN Carbon #4
Gearing - PN Pro Match 7T
Notes - Shortened top shock with spacer in kit + new tires running amazing. Couldn't match my 3.92 fast lap, probably because my best races usually happen on the 2nd run of the batteries.
Should be able to upload photos next month. Posted to the facebook group again for now.
Date- 07/29/2024
Race Time- 329.1
Chassis- MR-03
Wheelbase- 98mm
Motor- Stock
#2395
MA-020
Date-7/7/24
Race Time-357.27
Fastest Lap-4.39
Chassis-MR-03
Body-911
Wheelbase-90mm
Tires F Reflex 40 R unknown
Motor-stock
Batteries- PN 750
Got the MA-020 working a little better with the reflex front tires but could still use some work.
Date-7/7/24
Race Time-357.27
Fastest Lap-4.39
Chassis-MR-03
Body-911
Wheelbase-90mm
Motor-stock
Batteries- PN 750
#2396
Location-Orlando FLRace Time- 6:36.62Fastest Lap-4.63
Chassis-MR-03Body-McLaren F1Wheelbase-98mmTires-Fronts Kyosho 30, Rears Kyosho 10Motor-StockBatteries-SILVER HORSEFront Springs- Kyosho redsT-Plate- kyosho carbon softMotor Mount-Stock MMDampener (If applicable)-N/ADampener Fluid (If applicable)-N/AGearing-stock and 7T pinion
#2397
Class - Box Stock
Date - 7/2/2024
Location - Iowa
Race Time - 324.620
Fastest Lap - 3.911
Chassis - MR-03 MM
Body - McLaren 12C
Wheelbase - 98mm
Tires - PN KS Medium / Marka V1R10
Motor - Stock
Batteries - Orion 750 SHO
Front Springs - Green
T-Plate - Kyosho Carbon Firm
Motor Mount - Stock
Dampener (If applicable) -
Dampener Fluid (If applicable) -
Gearing - 7T, stock diff
Date - 7/2/2024
Location - Iowa
Race Time - 324.620
Fastest Lap - 3.911
Chassis - MR-03 MM
Body - McLaren 12C
Wheelbase - 98mm
Motor - Stock
Motor Mount - Stock
#2399
Really good to see all the racers posting! Welcome to the new guys! CCW is going to be a challenge for me with this quick layout. I'm going to try switching out some front tires on my Stock, Porsche, and BoxStock to get them to turn better in the switchbacks.
3036Likes
