Like Tree178Likes
Futaba 10PX
Old 05-17-2024 | 06:15 PM
  #316
smanders's Avatar
Originally Posted by shortcut3d
Checking if the operation of the DSP button is normal.
i just checked. My DSP button has the same click feel as the PWR button.
smanders is offline
Old 05-18-2024 | 12:39 AM
  #317
Originally Posted by Roelof
Cool to see that updated, thanks. With SR there was a benefit (in measurements, anyway) of not running in SR mode without an SR servo. Do you know if something similar happens in UR mode with a normal digital (Non-SR/UR) servo? (Or similar benefits running an R404 with a normal digital servo)
ijdod is offline
Old 05-18-2024 | 12:52 AM
  #318
This was measured with the v2.3 firmware the transmitter came with. I never had the urge and need to update it, we are now at V12. I can imagine the slower 278 Hz in SR mode could be fixed in a later firmware. Personally I do not think you will notice a lot of difference, on the other hand, there is no need to run the SR mode if you only run non SR servo's, in T-FHSS mode it works the same and you have telemetry so at least you can read the receiver battery
Roelof is offline
Old 06-08-2024 | 11:52 AM
  #319
choisan's Avatar
new to 10px, jsut wonder what actuall addition thing is requried for? my versio doesnt come with original lipo.
wonder how many still are using AA battery (recahrgeable)?
choisan is online now
Old 06-08-2024 | 04:24 PM
  #320
I use https://www.amainhobbies.com/protek-...k-5188/p165091.
malkiy is offline
Old 06-08-2024 | 11:12 PM
  #321
choisan's Avatar
Originally Posted by malkiy
to use this or the lipo, do i have to buy the lipo spacer? sorry to ask that as i am out for meetings and not having chance to see what the package actually came with even though the manual mentioned to use the lipo spacer and kind of not written in manual as content included
Old 06-10-2024 | 11:14 AM
  #322
I am not using a spacer in mine. I don't abuse my radio so I don't care if there is a little bit of battery movement.
choisan and hunterdawg like this.
malkiy is offline
Old 06-16-2024 | 02:37 AM
  #323
Spillertwo's Avatar
Default Touchscreen problem
I did a touch screen calibration and now can not use the menu and user menu buttons anymore since the touchscreen is not working anymore.
I saw other people did have the same issue before in this thread but never saw a solution to the problem.
Did anybody find a solution or how did they fix the issue ?
Spillertwo is offline
Old 06-17-2024 | 10:49 AM
  #324
Spillertwo's Avatar
Got in touch with Futaba service center. No reset function exists for the touchscreen problem after calibration. So had to send it in for repair. Wait and see how long it will take and if it will be fixed under warranty.
Old 06-18-2024 | 09:35 AM
  #325
AMZ's Avatar
AMZ
Do not worry , they are really good about warranty stuff and turnaround times.
AMZ is offline
Old 06-20-2024 | 11:08 AM
  #326
Spillertwo's Avatar
You were correct, transmitter fixed for free and after three days already on its way back.
Good job from the Futaba service center.
Now if only they would delete this "calibration" function from the menu, they would surely save themselves some work in the future and some frustration for the customers.
Old 06-23-2024 | 12:37 AM
  #327
I’m having problems with my 10PX and binding. I’m using R1 Wurks ESC and Gen3 Servo. Right now using digital servo as the channel steering because SR and UR so odd things. First, the centering between Digital Servo, SR and UR varies wildly enough it can’t be trimmed out. Second the range of motion is decreased with SR and UR almost like there is an end point adjustment. Third sometimes I need to reverse both ch1 and ch2. Sub-trim and EPA are all at 100 when binding. The only change is the protocol speed.
shortcut3d is offline
Old 06-25-2024 | 06:45 PM
  #328
...but what is your receiver as you did not mention which model it is as that will probably be most important piece of data for giving you guidance.
figgie is offline
Old 06-25-2024 | 07:20 PM
  #329
Futaba R404SBS-E F-4G T-FHSS 4-Channel Telemetry Reciever
Old 06-26-2024 | 01:42 AM
  #330
The servo is compatible with SR and UR? Keep in mind that a normal digital servo if not specified will not work on SR/UR
Roelof is offline
