Motor Testing and Comparisons >
Like Tree533Likes
Old 05-12-2024 | 12:28 AM
  #31
Not sure if my question deserved its own thread, so posting here.
How do you adjust timing going from a standard rotor to a long high torque rotor? Keep the timing the same or advance?
shortcut3d is offline
Old 05-12-2024 | 11:00 AM
  #32
trilerian's Avatar
Do you want the quick answer or the long winded one?
I'll start with the quick answer. I would leave the timing in the same spot and test. Then I would drop the timing by a degree or two (difficult...) and go up a tooth on the pinion. If you had optimal timing and gearing to start with, it is unlikely that advancing the timing would be of benefit.
OffRoadJunkie likes this.
trilerian is offline
Old 05-13-2024 | 05:40 PM
  #33
OffRoadJunkie's Avatar
What motor do you have?
OffRoadJunkie is offline
Old 05-13-2024 | 08:11 PM
  #34
R1 Wurks V21-S 17.5T and 13.5T. Upgrading with the ROAR long rotor.
Old 05-14-2024 | 05:50 AM
  #35
My experience with R1 and the long rotor was use the same timing but adjust the gearing. Larger pinion and/or smaller spur.
OffRoadJunkie and shortcut3d like this.
mbrienzo is offline
Old 05-14-2024 | 07:41 PM
  #36
STLNLST's Avatar
Originally Posted by K4IZEN
Would love to see these two motors tested
  • HW G4R
  • Team Exalt Phoenix Gold
The Exalt is a killer motor. I tested their 21.5 motor. Rotor strength is really nice and the motor runs killer on the track.
STLNLST is offline
Old 05-20-2024 | 08:52 AM
  #37
I finished testing the HW G4R. It's a really good motor. I just have to edit the film before I post it.
BigBuckORamma and shortcut3d like this.
Old 05-25-2024 | 11:04 PM
  #38
Here it is. I need to do better editing, but I really hate editing.
https://youtu.be/ZPKgKT_vb0I
trilerian and TOM MAR like this.
Old 05-26-2024 | 08:02 AM
  #39
STLNLST's Avatar
you’re in Sacramento or near it correct? In your video you stated that the G4R had the highest rotor you have tested. Off the shelf I currently have 4 brands that average 1800 on both my Fantom Facts machine as well as the WMS checker. Curious to see if you get the same numbers.
STLNLST is offline
Old 05-27-2024 | 11:04 AM
  #40
trilerian's Avatar
Makes me want to go out and buy a G4R motor, and I don't run stock anymore, lol.
Old 05-28-2024 | 01:20 PM
  #41
I'm near the south Sac area. What brand are they?
Old 05-28-2024 | 04:58 PM
  #42
So the HW 17.5 is putting out 25K rpm and 3300 KV at ~5-6amps? Meanwhile I get not much more out of my brand new Team Powers 13.5T at the same 5-6amps with 26.6K rpm and 3700KV.....
River19 is offline
Old 05-28-2024 | 05:45 PM
  #43
True, but you will have a lot more torque. You should be getting around 26k RPMs, right?
gigaplex and River19 like this.
Old 05-29-2024 | 03:49 AM
  #44
Yes when setting the timing I landed on ~43 degrees I believe which gave me 26,500 rpm with KV of 3724 pulling 5.3amps
I tested my Motiv MC5 17.5T and IIRC I was getting about 24K rpm with their factory set 47 degrees of timing which was showing slightly less timing on the analyzer. I will hook up the MC5 again today as it isn't installed in anything right now. I am running two TLRs with New Wave 17.5s now, which I do not have readings on.
EDIT: So the MC5 17.5 comes "factory set" at "47 degrees" which measured 43 degrees and produced 21,178 rpm and 2901 KV @4.3amps. I tweaked the timing to a measured 46 degrees (so +3 degrees) and got 21,480 rpm 2983 KV @ 5.1 amps..........I realize different analyzers and conditions etc but just some fun additional data points.
River19 is offline
Old 05-29-2024 | 08:40 AM
  #45
TonysScrews's Avatar
If the MC5 17.5 is anything like the 21.5 and 25.5 MC5's they like low timing and a lot of gear. They are torque monsters that the analyzer isn't showing you.
River19 likes this.
TonysScrews is offline
