Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-01-2022 | 08:53 PM
  #3196
Raman's Avatar
Originally Posted by TurboThirdGen
Thanks bud! I haven't had the chance to order some filament yet, So I have yet to print and test out the 2 splitters I modified. I'm sure they'll need a little tweaking. For the Carrera splitter I'd like to better match the outcrop on the lower front bumper instead of just the long radius curve.
I also am trying to figure out a way to turn one of the splitters into a rear diffuser for the speed run rig. I'm positive I can make it work, I'll just have to get creative. Once I get a little further into Tinkercad, I may try my hand at some side skirts as well.
So then how did you install the tail pipes?
Raman is offline
Old 04-02-2022 | 04:58 AM
  #3197
They were side by side pipes (oo) with a metal strip for attaching. I used my dremel to cut long ways to make it two single exhaust tips with a thin, long strip of metal protruding from the top. I then bent the metal to fit the curve inside the back bumper, and used Gorilla double sided tape.
Raman likes this.
TurboThirdGen is offline
Old 04-04-2022 | 08:02 PM
  #3198
Default First diffuser prototyped for the speed run rig
So I got busy today on the diffuser for the 50927 Lancer Evo VII body.
it's a one-off, as it's designed to mount specifically on the Yeah Racing Adjustable Toe Mount TATT-019BU.
I plan to make the others to mount on the standard bumper mount though. This is really just making sure I can do it, so subsequent designs will have improvements.
The deck is 3mm thick and the wings are 2mm thick, it has a centering ridge and also protrusions around the screw holes so they'll sit inside the countersunk holes in the YR mount without breaking the piece when tightened down. Also a cutout specifically for the muffler I have mounted on my body.
I really need to get some filament. But it should fit pretty well.
Raman and Eotz like this.
Old 04-04-2022 | 08:28 PM
  #3199
Raman's Avatar
Wish I had your 3D drawing skills. I stink at it
Raman is offline
Old 04-05-2022 | 05:17 AM
  #3200
Before I messed with the headlight buckets, I'd never done it before. The diffuser is the first piece I built from scratch.
You should check out TinkerCad. It's a Cad website, and it's free. It's pretty easy to use for me but there are loads of free tutorials out there
Old 04-07-2022 | 05:31 AM
  #3201
Does anyone have a TT02-RR setting sheet? I cannot find one anywhere
Qatmix is offline
Old 04-07-2022 | 05:37 AM
  #3202
Or a TT02-R setting sheet. Thanks
Qatmix is offline
Old 04-07-2022 | 07:13 AM
  #3203
IndyRC_Racer's Avatar
If you download the Tamiya TT-02D Type-S PDF manual from Tamiya, towards the end is a setup sheet (page 25). While I realize this isn't exactly what you are asking for, this setup sheet is fairly detailed and might be better than nothing. Here is a link on Tamiya.com where you can download their R/C manuals
https://www.tamiya.com/english/rc/manuals.htm
Addionally you can find a setup sheet for the Tamiya TT02 Type-SR in the manual (page 22). This kits comes with Tamiya Part# 54967 (https://www.tamiyausa.com/shop/optio...ble-sus-mount/) which allows much more adjustment for rear toe. Obviously the Type-S kits use different suspension components than the regular & R kits.
I did a quick google search and found the following website that has an online editable setup sheet for the Tamiya TT-02 Type S kit. Again this isn't specifically for the R or RR kits, but you might find it helpful.
https://site.petitrc.com/reglages/tamiya/setuptt02/
https://www.petitrc.com/index.php?/s...t.html/#Tamiya
I'm sure if someone did an exhaustive internet search they might find a basic TT-02 or TT-02 R/RR setup sheet. However since Tamiya provides their manuals in PDF format it wouldn't be too difficult for someone to create their own custom setup sheet for personal use using an existing setup sheet.
Hope this information helps.
IndyRC_Racer is offline
Old 04-07-2022 | 07:46 AM
  #3204
Thanks for the reply. I have a TT02-SR sheet that I am working on. I am however after a setting sheet for the std TT02 Style Chassis. I know one exists (in paper form at least), I just do not have one to scan etc.
Qatmix is offline
Old 04-07-2022 | 09:23 AM
  #3205
Mitamiya's Avatar
Default TT-02R
I think I might have one, I’ll check for you this evening.
Qatmix likes this.
Mitamiya is offline
Old 04-07-2022 | 09:51 AM
  #3206
Superb, thanks A scan would be fantastic
Qatmix is offline
Old 04-11-2022 | 05:52 AM
  #3207
Default Carbon damper stay II alloy collar top hat thingamies
Hello all , lost one of the alloy top hat collar thingamybobs that holds in the upper arms on , do any of you good folks know if such things are available as spares ?
be a shame to have to get another full tower set for one small part 😕
Thankyou for any assistance 😊
Pinkgold88 is offline
Old 04-11-2022 | 08:56 AM
  #3208
Hope this is the right place for this question. Just bought a TT02R. Im up to installing alloy steering from Yeah Racing. Problem is I have tightened the turnbuckles all the way and the steering still has a load of toe in. Is the issue with the alloy steering? Or could it be the alloy front knuckle? I have attached them to the end hole on the front knuckle.
Last edited by Infinitesd; 04-12-2022 at 03:28 AM. Reason: Amazed that English is my first language. Horrible.
Infinitesd is offline
Old 04-11-2022 | 12:32 PM
  #3209
Originally Posted by Infinitesd
Hope this is the right place for this question. Just bought a TT02R. Im up to installing alloy steering from Yeah Racing. Problem is I have tightened the turnbuckles all the way and the steering still has a load of toe in. Is the issue with the alloy steering? Or could it be the alloy front knuckle? I have attached them the end hole.
Only issue there should be with the YR alloy steering set should be the slop. Perhaps try either shorter turnbuckles or shorter turnbuckle ends?
Old 04-11-2022 | 12:33 PM
  #3210
The shock tower piece or the one opposite?
Here's a set of two aluminum upper arm mounts opposite the shock tower.
https://www.ebay.com/itm/40327455548...AAAOSwvNRhgsCN
