Tekin Rx8 Gen3 Thread >
Like Tree85Likes
Old 09-08-2020 | 10:16 PM
  #346
Originally Posted by Tekin Prez
It should handle the slightly higher voltage fine as long as you are using a proper 6s motor.
Perfect - thank-you!
"Properly specced motor" is my middle name
1350-1550 geared for ~75kmh gives me mostly 80A absolute peaks with an occasional 100A
oodeano is offline
Old 09-08-2020 | 11:21 PM
  #347
Kajman's Avatar
Tekin Prez, when can we expect new esc? Any rumors?
Kajman is offline
Old 09-17-2020 | 10:21 AM
  #348
Kajman's Avatar
One more question, is RX4 and RX8 software the same in terms of low end start?
Kajman is offline
Old 09-17-2020 | 04:20 PM
  #349
morgoth's Avatar
I was about to service my T8 GEN3 1900kv motor and replace the bearings, but I can’t get the rear bearing out :/
anyone has tips to get it out when it’s really stuck in there? I put a cylinder in there and tried to tap it out, but it doesn’t move at all.
When I swap the bearings in my nitro engine, it put into the oven. Would that help when I use 80C? Or will I damage something when I put the sensor board with bearing in it?
morgoth is offline
Old 09-18-2020 | 12:13 AM
  #350
Kajman's Avatar
Kajman is offline
Old 09-18-2020 | 05:38 AM
  #351
morgoth's Avatar
Originally Posted by Kajman
I tried this. With a small nutdriver on the bearing and tapped it lighly with a hammer. The bearing didn't move half a millimetre :/
I didn't want to tap harder, because when I screw it up, I can't race this weekend, so the rear bearing is still in there. I still spins smooth and without slop, but it's kinda dry so I'd like to replace it. The front bearing was getting sloppy but that one is already replaced.
morgoth is offline
Old 09-18-2020 | 06:27 AM
  #352
Kajman's Avatar
But did you put f.e. plasticine or something simliar there in the middle?
Tenkotakeover likes this.
Kajman is offline
Old 09-18-2020 | 03:25 PM
  #353
You can try using a bolt/nut/washers/and a range of sockets.
Bit hard to explain but use an oversize socket on one side to catch the bearing (sort of like a cup).
Use a suitable bolt that the head doesn't completely go through the bearing (the head works against the inner race) but it has to be long enough to have a washer and nut on the other side of the socket.
The bolt is on one side of the bearing, the socket the other to catch the bearing, the washer and nut outside the socket.
You then just hold the nut and tighten the bolt.
It should push the bearing out without you having to use any force which might damage something.
morgoth likes this.
Craig1 is online now
Old 09-19-2020 | 01:55 PM
  #354
morgoth's Avatar
Thanks for the tip! This is a good idea.
I will try this after the weekend.
morgoth is offline
Old 09-25-2020 | 11:16 AM
  #355
I have used this method and it works well.
Dartagnan_007 is offline
Old 09-28-2020 | 01:42 PM
  #356
Tekin Prez's Avatar
Team Tekin
The Rx4 is detuned a little since its job is to go slow and the Rx8's job is to go fast... No one spends much time in the first little bit of throttle on a Rx8 like they do in a Rx4.
Tekin Prez is offline
Old 09-28-2020 | 01:44 PM
  #357
Tekin Prez's Avatar
Team Tekin
We are always working on something... New products or improvements to existing platforms. Rx8 is a pretty solid hardware platform that we do not intend to change physically anytime soon.
Old 10-24-2020 | 03:45 PM
  #358
MarkBrown's Avatar
Originally Posted by savage24x
Can the 30x30x7 fans take 7.4v? They're the only fans I can find in that slim profile. I have one connected directly to my receiver which is getting 7.4v from my ESC.
Fan in question: https://www.teamtekin.com/shop/index...product_id=118
Originally Posted by Randy_Pike
Yup, they can.
I connected the fan that came with my RX8 Gen3 to my receiver (to free up the ESC fan connector for Hotwire use), with BEC voltage 7.4V. The fan ran for 2-3 seconds, then stopped, then a tiny puff of smoke came from the fan. Is the replacement fan that Tekin sells different from the fan that comes with the RX8 Gen3?
MarkBrown is offline
Old 10-26-2020 | 04:08 PM
  #359
Tekin Prez's Avatar
Team Tekin
The fans we sell seperately are the same as what comes with the Rx8. They are only rated to 5v but should have worked fine on 7.4V. We have even tested them on 8.4v 2s lipo and they seem to work fine. Must have been something damaged in that one if you saw smoke puff and now dead. Perhaps a broken wind in it.
Old 10-28-2020 | 07:12 PM
  #360
lowspark's Avatar
I've found that fans run only one way... if you reverse the power to them, they will let the magic smoke out...
lowspark is offline
