Tamiya TB-Evolution IV
#2881
Originally posted by JDM_DOHC_SiR
Lower Bulkhead with swaybar mount 3455844
Center post 3455845
There ya go
-Dave
Center post 3455845
There ya go
-Dave
They seem like odd tamiya part numbers, even if it was 55845, that seems odd to be a 55 number, shuld be a 53 number?
#2882
nevermind, the numbers seem to work
Does anyone know if the you order the bulkheads, do you get both end or just one?
if its just one, if I purcahse one for the front, are they identical to the orginal ones, just a one piece design VS the 3 piece?
#2883
recently, my evo4 has developed a very bad habit..... spur stripping!!!!!
it strips every single spur i replaced after a crash (be it minor or major crash) within a battery pack (every pack = 1 spur!!!)
I'm not sure is it because of tight centre shaft or bent shaft of is it motor not properly / tighly mounted.
Any1 has any solution?
#2884
#2886
Jeff,
in my earlier runs with the car, this did not occur until recently.
Are you facing the similar issue?
Jeff,
I have the same problem with the Evo3 SL and Evo4 and since it's so much work to replace the spur gear I ended up running the 415 most of the time.
#2889
sometimes, it's a minor crash.
and because of this, i'm going back with my 415.
Jeff, I have run a oneways, diffs, and a spool and have gone as far as to bend the big thick driveshafts and no problems with the spur. I have to believe the problem is elsewhere.
BTW, I have only had one crown gear go out too and that was my fault for not using Loctite on the screw. IMO this car is one of the toughest cars I have seen!!!
#2892
Originally posted by hawker
i just got an email back from Rainbow Ten saying they had the bulk heads and center poct in stock:
3455844,TAMIYA,5160YEN,3455844 LOWER BULKHEAD
3455845,TAMIYA,1380YEN,3455845 CENTER POST
I thought that I posted the correct numbers
-Dave
#2894
[QUOTE]Originally posted by Csaari77
Can anyone tell me what the weight rating is for the springs that come with this kit? I would also like to know about the rating for the tuned spring set. [/QUOTE
I believe the yellow springs are about 13.5 lb. This is an average rating as every batch, and spring, is slightly different.
#2895
http://www.thard.co.uk/rc/TRF415/TRF415pages.html
2Likes
