Tamiya TB-Evolution IV >
Like Tree2Likes
Old 04-17-2005 | 12:32 AM
  #2881
hawker's Avatar
Default Re: Re: EVO MS parts
Originally posted by JDM_DOHC_SiR
Lower Bulkhead with swaybar mount 3455844
Center post 3455845
There ya go
-Dave
They seem like odd tamiya part numbers, even if it was 55845, that seems odd to be a 55 number, shuld be a 53 number?
hawker is offline
Old 04-18-2005 | 12:04 AM
  #2882
hawker's Avatar
nevermind, the numbers seem to work
Does anyone know if the you order the bulkheads, do you get both end or just one?
if its just one, if I purcahse one for the front, are they identical to the orginal ones, just a one piece design VS the 3 piece?
hawker is offline
Old 04-18-2005 | 01:00 AM
  #2883
Windtalkers's Avatar
recently, my evo4 has developed a very bad habit..... spur stripping!!!!!
it strips every single spur i replaced after a crash (be it minor or major crash) within a battery pack (every pack = 1 spur!!!)
I'm not sure is it because of tight centre shaft or bent shaft of is it motor not properly / tighly mounted.
Any1 has any solution?
Windtalkers is offline
Old 04-18-2005 | 01:23 AM
  #2884
jeffreylin's Avatar
This is the same problem as the old bevel/one-way gear problem. Essentially the weakest link in the system will give to the force of the impact. It used to be the one-way gear, then Tamiya fixed it with a back plate in the Surikarn edition, and the bevel gear became the problem. With proper shimming, Evo4 bevel gears no longer strips like the Evo3 SL (not as much anyway) so now the force goes to the next gear in the system, which is the spur gear.
jeffreylin is offline
Old 04-18-2005 | 02:18 AM
  #2885
Jeff,
in my earlier runs with the car, this did not occur until recently.
Are you facing the similar issue?
Old 04-18-2005 | 02:29 AM
  #2886
jeffreylin's Avatar
Jeff,
Did you have the same kind of crash and did you break anything?
I have the same problem with the Evo3 SL and Evo4 and since it's so much work to replace the spur gear I ended up running the 415 most of the time.
Old 04-18-2005 | 02:52 AM
  #2887
sometimes, it's a minor crash.
and because of this, i'm going back with my 415.
Old 04-18-2005 | 07:37 AM
  #2888
berger's Avatar
Can someone repost the shimming guide for the evo 4 please, ive done a few searches but due to the minimum search string of 3 i cant get the results i would like, thanks!
berger is offline
Old 04-18-2005 | 10:06 AM
  #2889
fraz's Avatar
You are either setting your mesh too tight, or too loose, or not tightening the motor screws enough, or you have debris or something wrong with the pinion teeth. I run mod (up to 8x1) and have only stripped one spur gear ever and I have run a bunch. The one spur gear I stripped was when another driver drilled me at the end of the straight.
Jeff, I have run a oneways, diffs, and a spool and have gone as far as to bend the big thick driveshafts and no problems with the spur. I have to believe the problem is elsewhere.
BTW, I have only had one crown gear go out too and that was my fault for not using Loctite on the screw. IMO this car is one of the toughest cars I have seen!!!
fraz is offline
Old 04-19-2005 | 02:15 AM
  #2890
alan1467's Avatar
The alloy centre post from the MS kit is coming out a a 49*** number in May
49356 - TB Evolution IV Aluminum Center Post
Alan
alan1467 is offline
Old 04-19-2005 | 02:19 AM
  #2891
hawker's Avatar
i just got an email back from Rainbow Ten saying they had the bulk heads and center poct in stock:
3455844,TAMIYA,5160YEN,3455844 LOWER BULKHEAD
3455845,TAMIYA,1380YEN,3455845 CENTER POST
hawker is offline
Old 04-19-2005 | 05:32 AM
  #2892
JDM_DOHC_SiR's Avatar
I thought that I posted the correct numbers
-Dave
JDM_DOHC_SiR is offline
Old 04-19-2005 | 09:49 AM
  #2893
Csaari77's Avatar
Can anyone tell me what the weight rating is for the springs that come with this kit? I would also like to know about the rating for the tuned spring set.
Csaari77 is offline
Old 04-19-2005 | 10:30 AM
  #2894
[QUOTE]Originally posted by Csaari77
Can anyone tell me what the weight rating is for the springs that come with this kit? I would also like to know about the rating for the tuned spring set. [/QUOTE
I believe the yellow springs are about 13.5 lb. This is an average rating as every batch, and spring, is slightly different.
Obsidian is offline
Old 04-19-2005 | 10:32 AM
  #2895
Check out this site for a complete spring chart.
http://www.thard.co.uk/rc/TRF415/TRF415pages.html
Obsidian is offline
