Team Associated B6 & B6D thread
#3994
I would pick up the 12g brass as well to experiment with. I have been running outdoors lately and the heavier my car is the better its been. I was just over 1600g last club race with the standup car. However...indoors (ocrc) I had the laydown with the 12g brass, I tried the 25g and it felt lazy. Also, play around with the rear shock location if running the laydown. I preferred shocks on the front as opposed to the rear at ocrc. Didn't reduce grip much but felt quicker through the corners.
#3995
Pop Survey: I'm still debating about picking up a B6/D somewhere around the New Year. I am curious about actual numbers and not about "this other guy at the track". So if you have had to personally replace the items below due to breakage, let me know how many times.
How many have you replaced:
Front Tower:
Rear Tower:
Chassis:
Front Tower:
Rear Tower:
Chassis:
Since you're asking: If your hobby shop does not stock towers then I would suggest having one handy just in case. It goes without saying that none of these items break without crashing; so for any crash you risk breaking something. How often, how hard, and how your track conditions are that can increase your chances (chain link fence!) are pretty subjective. But, if you're worried about it, then best to have parts available to keep your race or practice day going.
I haven't heard of any comments about any replacements/issues with the chassis or rear tower.
#3996
#3997
You move the shock tower to the front of the tranny case (laydown only) and change the bottom shock eyelets and then mount them to the front of the arm. Schelle has an optional rear tower that uses the longer b5m rear shock bodies and allows you to use the short shock eyelets when mounting the shocks on the front/rear of the arm. The B6 manual can be found on rc10.com and will show all the laydown specific stuff.
#3998
I've read through this thread and don't remember it mentioned.. and as I just got this buggy in and was giving it a once over ...
What are the ball studs on the inside of each arm for?
#4001
BOOM!!!
Everything's clear when you know the answer...
#4002
For those using jconcepts pindowns. On carpet.are you using the jconcepts insert that comes with them or something like an aka red insert? The aka insert is widely used at our track on the shumacher minipins
#4003
B6d 4 gear stand up
Guys do you know where I can find the instructions to build the 4 gear stand up box.
Cheers Mark
Cheers Mark
#4004
