TLR 22 3.0 Race Kit Thread! >
Like Tree26Likes
    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Old 03-10-2016, 08:23 PM
  #2326
67GTA's Avatar
Frank Root - Congratulations on RC Car Action Car of the Year Award for the 22 3.0. You pretty much owned the May issue - well done!!
67GTA is offline
Old 03-11-2016, 09:17 AM
  #2327
Mudcat981's Avatar
+1 Great car!
Mudcat981 is offline
Old 03-11-2016, 11:03 AM
  #2328
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Mudcat981
+1 Great car!
Thanks guys!
Frank Root is offline
Old 03-11-2016, 06:36 PM
  #2329
Mfrisz's Avatar
Has anyone tried the 22 3.0 with 4-gear, what is the difference between the 3 and 4 gear?
Mfrisz is offline
Old 03-11-2016, 11:15 PM
  #2330
Is anyone having terrible with ball cups popping constantly if you land slightly weird or brush a coping. Front and rear?
Cub86 is offline
Old 03-12-2016, 06:12 AM
  #2331
Kass's Avatar
Trader Rating: 42 (100%+)
Poke a hole through the ball cup with a leather punch on nee bell cups so you leave them snapped in when you have to unscrew the ball studs
Kass is offline
Old 03-12-2016, 06:31 AM
  #2332
ryan432greening's Avatar
For those who paint their bodies with spray paint, what's your go-to paint? Is there something more affordable than the small hobby store spray paints that still look good and stick to the bodies well? What do you like and where did you get it?
ryan432greening is offline
Old 03-12-2016, 06:34 AM
  #2333
I've broken several parts from hard hits, but I have yet to have a ball cup pop off. However, I have never removed one from the ball stud for setup changes. When building, I drilled holes just big enough to get my 2mm driver into the hex head for easy removal without popping the cups off of the ballstud.
Before you install the new ball cups, I recommend doing this.
Old 03-12-2016, 01:26 PM
  #2334
Davidka's Avatar
Trader Rating: 86 (100%+)
Your ball cups must be shot. If you're going to go through the trouble of punching/drilling, do it to new ball cups. Race weekend is too short for preventable DNF's.
Different question: Do AE's ball ends fit TLR'S ball-studs?
Davidka is offline
Old 03-12-2016, 01:43 PM
  #2335
rangerjkb's Avatar
Trader Rating: 45 (100%+)
+1 I used a leather punch tool (from inside to out) as mentioned on a previous post, that made clean holes to access with a hex driver and adjustments very quick and easy.
rangerjkb is offline
Old 03-12-2016, 03:36 PM
  #2336
tsair's Avatar
I messed up the tip of my leather puncher trying to do this, so maybe use a body reamer and then drill?
tsair is offline
Old 03-12-2016, 04:46 PM
  #2337
Fabulous's Avatar
I have AE ball cups on my car. You will need ball cups, ball studs and tierods to convert. Works great and making adjustments easy
Fabulous is offline
Old 03-12-2016, 05:15 PM
  #2338
I remember seeing Maifield and Denney using B5 ballcups on their 22-4s at Reedy Race I think.
boucher is offline
Old 03-12-2016, 05:45 PM
  #2339
drepus's Avatar
Originally Posted by 68pontiac
I've never thought about this before, but I'm assuming the inverse applies as well? Moving the battery further forward could result in more weight shifting to the rear on power, potentially increasing on-power traction? Or is the benefit of having the static weight closer to the rear end of the car outweigh the weight transfer?
Having the battery farther forward will generally reduce steering into a corner but increase steering out of the corner on power. It will also reduce rear grip coming out of the turn..
If you need more steering into a corner try increasing camber, reducing caster or raise the roll centre. If you need more steering on power try reducing front droop(more limiters inside front shocks),stiffening rear springs or moving weight forward.
Our cars are optimized for dirt. On carpet the rear ends feel too planted and can give the car a general feeling of slight push. Standard things I usually end up with on carpet include using the optional "0" front caster blocks to increase steering overall, move the battery full or almost full forward, stiffer springs front and rear, and move the shocks out all the way on the arms.
drepus is offline
Old 03-12-2016, 07:55 PM
  #2340
Davidka's Avatar
Thanks for the tip. Did you use last-gen(smaller diameter) tie-rods?
Davidka is offline
