TLR 22 3.0 Race Kit Thread!
#2356
Both my stock and mod car are coming in around 1560-1565g range. I've gone lighter trying a low profile shorty and have returned to back to a full size shorty.
#2358
I'm not sure what else it could be than. I have a S6240 servo, Justock ESC and a 24k short stack motor. I thought those were all pretty light components. Maybe I need to try a different scale? I was using a hanging scale that was reading kg(1.62) instead of grams. On a positive note, this was the first kit I've ever assembled and it went together perfectly with zero issues. It is also my first 2wd buggy and I find it is easier to drive right out of the box than my 8ight E.
#2359
If looking to cut a little weight, where do you think is the best place to start? Titanium turn buckles? can't afford to do the whole lot at once so will slowly work through things.
Also I've never had any issues with turn buckles popping off. Before installing I do the same as others have said here drilling a hole in the top so you can unscrew the ball stud while still connected.
Gear diff: I'm running the standard TLR diff but to get it to fit without drag in the housing I had to shamfer the case on the lid side with a craft knife and then also shim that same side. Now running with zero drag. Next job is to try those kyosho Orings to stop the diff fluid escaping everywhere.
#2360
Super Moderator
Weight issues?
You could check the following items;
- Body, the more the paint on the body the heavier it will be.
- Wheels, are you running 2.2 inch wheels or the 2.4 inch wheels? 2.4 inch wheel and tire setups weigh less. However, each wheel size setup has its advantages and disadvantages.
- Speed control wires, do you have to much length? Even though you might be using 14 or 16 gauge wire extra length adds weight and resistance.
#2361
#2362
#2364
#2365
#2367
What rear hubs was Dustin Evans running at Cactus Classic? They look different with four holes for various mounting positions.
http://www.liverc.com/photos/albums/...c/DSC_6795/lg/
#2368
#2369
How do you attach the front end? what sort of weight saving have you achieved? Have you run it yet?
#2370
