Team Associated B4.2 Thread
http://www.teamassociated.com/parts/details/7260/
I did use a small drip of blue thread lock for grins.
not its not metric. Its a mini 4-40 nut.
I used these http://www.amainhobbies.com/product_...m-Mini-Nuts-10
http://www.amainhobbies.com/product_...inum-Locknut-5
Hideeho
Savox 1256 is a bit of overkill on torque & a bit slow for bitty buggy. Savox 1257 & 1258 are more the norm. A short servo is not required. If you have the 1256, it will be fine, but a faster servo will be nice at some point.
The main difference between b4.1 worlds & b4.2 is the bb shocks, aluminum steering blocks, hexes, & VTS slipper. Of those I would say only the aluminum steering blocks are a REQUIRED mod to the worlds. Your doing the hexes, so I would HIGHLY recomend getting some AL steering block as the next hopup, or replacement WHEN you break the plastic steering blocks. The bb's are nice & well made, but only a real benefit if your track is rough. I was rather unimpressed by the VTS. I would recommend the Avid triad or rcshox.com Garodisc.
I believe this is the part you were looking for:
http://www.amainhobbies.com/product_...-Bearing-GT2-2
I change mine about every 4 months, indoor track, no dust, usually change cars more than shock oil.
also selling a painted B4.2 body, new, needs to be cut.
http://cgi.ebay.com/ws/eBayISAPI.dll...32319#shpCntId
Hello guys, noob question. Just reading some PDF file on B4.1 and saw the file on 12mm BB Shocks. On the manual it says that if i want to use the BB i need spacers to fil the shock tower (front/rear). Questions is, where can i get those spacers?
B4.1:
Front/Rear - 0.090" black spacer
Rear Arm - 0.030" sliver spacer
Thanks in advance. Cheers
B4.1:
4Likes
