Team Associated B4.2 Thread >
Like Tree4Likes
Old 01-29-2014 | 04:32 AM
  #12331
greenruby79's Avatar
Originally Posted by Tradin Paint
Avid sells them. These are only needed if you are using the original B4.1 shock tower. The newer shock towers are modified to ensure spacers are not needed
Okay thanks. Which ones are the newer shock tower or i just get the B4.2 tower ...both the same? Cheers..
greenruby79 is offline
Old 01-29-2014 | 05:26 AM
  #12332
Grasschopper's Avatar
It was a running change to the same part number. Unless it's been sitting on the shelf at your LHS for a long time it should be the new tower. If you have an old tower and a new tower it is obvious that the area where the shocks mount is much thicker.
Grasschopper is offline
Old 01-29-2014 | 05:35 AM
  #12333
Ahhhh....thanks alot. I got it. Cheers
Old 01-29-2014 | 11:20 AM
  #12334
Suspended
Quick question guys. Started back into R/C during the early January with my Sc10rs. Anyways, I've gotten some more track time down and wanted to run buggy class. What do you think about the B5 compared to your B 4.2? I'm still wanting the B 4.2 though.
kcee91 is offline
Old 01-29-2014 | 11:29 AM
  #12335
Wildcat1971's Avatar
if you already have a b4, just run it. You just getting back into it anyway. if you dont have a car yet, might as well get the b5, and be on the latest platform. I am very sure that many drivers at w3 with be running the b5 soon and can give you setup help. You might want to wait for the b5m for W3, though.
Wildcat1971 is offline
Old 01-29-2014 | 11:43 AM
  #12336
Suspended
I don't have a buggy yet. Just wanted to get some opinions first before I jump and buy the B 4.2. Does it matter whether you have a midship setup or rear setup in the buggy class?
kcee91 is offline
Old 01-29-2014 | 11:53 AM
  #12337
well, that is the debate...They say RM is more for the beginning driver because its easier too toon, but I recently saw a novice driver get much better with the MM over RM. Since you have been racing for 3 weeks, the RM might be best. Maybe some of the more experienced W3 racers can assist you. but SRS is "supposed" to be a high traction mm style track. if "I" were your, I would get the B5M... but that is me.
Old 01-29-2014 | 12:11 PM
  #12338
gawith0413's Avatar
I have a NIB B4.2 kit if your interested...
gawith0413 is offline
Old 01-29-2014 | 12:20 PM
  #12339
predu's Avatar
for $15 less than a b5, without coupons codes and it is now outdated. your price is about $60 too high. at least.
predu is offline
Old 01-29-2014 | 12:27 PM
  #12340
Suspended
Didn't know that. I'll have to give it a try. I hope I can switch easy between the mid and rear like they did with the 4.2 on A Main.
kcee91 is offline
Old 01-29-2014 | 12:28 PM
  #12341
Suspended
Thanks for the offer. I'll let you know if I decide for a used or the new kit. I'd rather build it from the ground up. I made that mistake with the RTR SC10RS, but feel more comfortable after I actually took it apart to overhaul some of the parts.
kcee91 is offline
  #12342
two different cars, pick and go.
Old 01-29-2014 | 12:30 PM
  #12343
gawith0413's Avatar
It is the factory team kit, un-built. You can see my thread in the for sale section.
Old 01-29-2014 | 12:32 PM
  #12344
Suspended
Right. Are you referring to the upcoming track for Cactus or their current track? The current track is good, but felt a little loose last time I was there. It did grip though overall.
kcee91 is offline
Old 01-29-2014 | 12:34 PM
  #12345
the new indoor track. it supposed to be ready in march. then you will have a couple indoor med/high bite tracks. Personally, for those I would definitely give the b5m a go.
