Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-31-2014, 11:40 AM
  #12481
Grasschopper's Avatar
Trader Rating: 54 (100%+)
Originally Posted by ICBeloitRacer View Post
The hinge pins look OK to me, and the arms are moving freely. I can plainly see the difference in length between the shocks themselves, so I'll have to start with that. How many limiters should be in there?
All depends on the track and your handling. Kit setup is 2 spacers rear and 3 front.
Grasschopper is offline
Old 04-01-2014, 08:53 AM
  #12482
clw
Default A tower or C tower-difference?
I purchased a used 4.2 from one of the members here and notice it has the C rear hub tower with an unshaved chassis brace with no washer. From what I can tell this is a high grip setup. Our outdoor track is medium grip and goes down from there.
Would I benefit from ordering and changing back to an A tower?
clw is offline
Old 04-01-2014, 07:04 PM
  #12483
thecman26's Avatar
Trader Rating: 100 (100%+)
I would imagine, that would be way better than the C hubs!
The C hubs were used with a shaved u-brace to free up the rear end if I remember right?
thecman26 is offline
Old 04-05-2014, 11:24 AM
  #12484
3srcracing's Avatar
Trader Rating: 27 (100%+)
For any of those interested that still have a B4.2 I have a spare parts car with a couple of chassis and a custom body. Would be willing to trade for a servo.
3srcracing is offline
Old 04-05-2014, 12:24 PM
  #12485
Trader Rating: 173 (100%+)
Try the c hub and shaved brace. I liked it on a low to medium bite track better than the a hub.
thecaptain is offline
Old 04-05-2014, 05:09 PM
  #12486
Default Antenna Question
I got a plastic replacement antenna for my b4.2. This thing is 12" long!
It looks like there are a few extra inches coiled up in the receiver box.
How long should I make mine?
philo111 is offline
Old 04-05-2014, 08:18 PM
  #12487
Super Moderator
Which radio system do you have?
If you are asking about cutting the receiver wire, in general it shouldn't be cut. In the cases where it can be it is important to cut it to a specific length. The length is part of the tuning to the wavelengths it is receiving.
If you are asking about how tall the antenna should be, if it's a 2.4GHz radio you have lots of options. Many don't run a antenna tube at all, just leave the wire on the chassis, some run a short (say 3~4") tube, some run the full tube. If not a 2.4GHz deal probably best to run the full or nearly full height.
Dave H is offline
Old 04-05-2014, 09:24 PM
  #12488
It's a 2.4 radio. The stock set up for a RTR b4.2
philo111 is offline
Old 04-06-2014, 05:58 AM
  #12489
Originally Posted by MOmo View Post
Presume shaving the brace level with the rest of the "U" right?
the above setup is actually my home track.
I'm switching this up to mod and using the avid setup, thoughts on gearing my 8.5? I think I only have the 81t spur or the smaller 72t. Thoughts?
momo
Yep, shaved level. My home track as well ... :-)
34x17 is offline
Old 04-07-2014, 10:43 AM
  #12490
Trader Rating: 96 (100%+)
Getting my B4.2 dialed in but I stripped out the stock servo horn. Can I get some suggestions on which aluminum horn to use? Thanks.
eddiemoney13 is offline
Old 04-07-2014, 01:06 PM
  #12491
jsinclair's Avatar
Losi 22 series fits fine . or just replace the plastic one , would rather blow a horn than a $100+ servo.
jsinclair is offline
Old 04-07-2014, 02:08 PM
  #12492
thecman26's Avatar
That's what I have in mine, fits great!
Old 04-07-2014, 06:02 PM
  #12493
5th wheel's Avatar
Hello everyone
I am running the v2 shocks with bb springs on my b4.does any one have a link or know were I can get
the red O rings and black O rings for the top of the shocks. In bulk rather than a hobby shop on ae parts
thanks
5th wheel is offline
Old 04-11-2014, 01:50 PM
  #12494
Hey guys,
I'm new to racing and picked up a B4.2 with a trinity 6.5 duo 3 mod motor and a
a speed passion reventon speed control. I believe most people run 8.5-10.5 in the local mod class. Will this setup be able
To be dialed in to what I need ?
camps23 is offline
  #12495
Hey guys,
camps23 is offline
