Team Associated B4.2 Thread >
Like Tree4Likes
Old 05-05-2013 | 07:13 AM
  #4816
Cridd's Avatar
Originally Posted by ohrcrracer
hey guys i need some help with the setup on my b4, it has quite a bit of push around corners even without the throttle on, i am running it all factory minus brown springs up front, thanks
I would check your diff is not too tight then go to things that would help overall steering if that was not it. Battery forward, Stiffer rear spring, softer front. maybe 1* toe out.
Cridd is offline
Old 05-05-2013 | 07:16 AM
  #4817
bds81175's Avatar
Moderator
Do you have the right tires for the track you are on? Is your diff set too tight? D/R turned way down on the radio?
bds81175 is offline
Old 05-05-2013 | 07:19 AM
  #4818
Cridd's Avatar
Originally Posted by Jam-Air
For those interested,
Body can be purchased direct here:
http://www.andysrc.com/New-Products.php
Or from IERC at 909-810-7469
Thanks to the guys who were making fun, I thought this place was to share information to help us all. The cool thing about racing rc vs our real race car is that in rc people share info cause its a hobby
No shopping cart or Paypal? My mom always said patience was not my strong point, maybe an eBay store. Send me the link when I can one button purchase. Thanks.
Cridd is offline
Old 05-05-2013 | 07:21 AM
  #4819
bds81175's Avatar
Moderator
Originally Posted by thecman26
Ran my buggy again tonight and was very happy with it, though I was wandering if there was anything set-up wise to calm down my turn in? It seems really hyper twitchy turni in, mid turn and exit I am ok a lil slow but I can handle a little lazyness there....
Any ideas?
Sounds like toe out. Does it wander a bit aimlessly on the straights? Check where your front toe is and reduce it a bit.
bds81175 is offline
Old 05-05-2013 | 07:39 AM
  #4820
F18engineguy's Avatar
Default NIB LRP FLOW WORKS TEAM 165.00 SHIPPED
New in the box. 165.00 shipped and I am firm on the price.
paypal is [email protected] first to pay gets it. Seal in the box
F18engineguy is offline
Old 05-05-2013 | 08:38 AM
  #4821
The diff is set correct from.the last time I checked, I have the tires on it that are hokking up right now at my track, and d/r all the way turned up
ohrcrracer is offline
Old 05-05-2013 | 08:42 AM
  #4822
Matt Trimmings's Avatar
Brown is pretty soft, have you tried going up in spring rate? Most setups call for Green fronts. What type of track?
Matt Trimmings is offline
Old 05-05-2013 | 09:54 AM
  #4823
One hobbies, packed down dirt, brand new layout last Wednesday but same material I believer
Old 05-05-2013 | 09:59 AM
  #4824
Isnt that a clay track? what tires are you running?
Old 05-05-2013 | 10:23 AM
  #4825
Tradin Paint's Avatar
It's not clay, it's similar to the dirt at Competition
Tradin Paint is offline
Old 05-05-2013 | 10:27 AM
  #4826
eww....i would say try a stiffer front spring, i would go to a black then a green and see how it feels. I always ran brown fronts on the v2's but have never ran them on the bb's. The one time i ran the bb's at CH i ran 1.6's all the way around with 32 front 27-30 rear with green fronts and green rears (i think..could have been white rears).
Old 05-05-2013 | 11:08 AM
  #4827
CHIZZLE's Avatar
What front tires/inserts are you running?
CHIZZLE is offline
Old 05-05-2013 | 11:50 AM
  #4828
thecman26's Avatar
R/C Tech Elite Member
Originally Posted by scoopdaloop
I'm running maifields exact set up from Jconcepts nationals.. posted on rc10.com
I'm running barcodes in front and holeshots rear on a med bite clay track. I went from 1 degree toe out to 0 degree and it calmed my steering down a lot.. I also lowered my ride height to 23.5mmf and 23.5mmr..
How is your rear traction? post your setup and you will get more responses.
Also, I came from 1/8 nitro where you can really get into your physcial steering wheel and crank it both ways.. I tightened my wheel on my M11 just a bit and it slowed down my hand a lot.. I know thats not tuning but it helped me smooth out my steering and "flow" better instead of jerky steering.
I am running pretty much box stock setup except a lil thicker shock oils, 30wt front oil and 35wt rear oil, avid shock pistons (1.5/1.1), shaved u-brace with 1mm spacers, c-hubs middle, Ions rear tires and barcodes front changed to rips front with not much difference, 0* front toe changed to 2* with little change, 3.5* rear toe block. Indoor bumpy high bite clay, turned down steering speed to 95% hellped a little. Shorty pack one block from all the way forward.
Rear traction is great btw! It is just a bit twitchy initial turn in and a lil lazy mid and exit. I have plenty of servo (Savox 1258) so that isnt it.
That's about it.
thecman26 is offline
Old 05-05-2013 | 11:52 AM
  #4829
thecman26's Avatar
I was straight up front, doesn't wander, changed to 2* toe out for the main and it seemed to help a little. I am a truck guy who wants to get better, so buggy is a whole new driving style to me.
Old 05-05-2013 | 12:27 PM
  #4830
Autocratic's Avatar
Any reason you're running so much toe front and rear on high bite clay? All that toe can make the car twitchy, especially in the rear. Forward bite might be great but when you want to rotate the car it won't want to.
Autocratic is offline
