Team Associated B4.2 Thread >
Like Tree4Likes
Old 11-04-2013 | 10:39 AM
  #10981
Autocratic's Avatar
Originally Posted by bilster44
I wonder if you HAVE to use their "grooved" thrust washers in the diff?
Only one is grooved, and it's the black washer that rests against the bearing. The other washer is standard and not grooved.
I'm sure their wouldn't be any disadvantage to not running their thrust bearing.
Autocratic is offline
Old 11-04-2013 | 01:39 PM
  #10982
Woulvesbaine's Avatar
I seem to have bent the front two camber links a little over time. Any preference or differences between the Lunsford, JC or Associated titanium turnbuckles? Really only need the front two but prices on sets are not that bad.
Woulvesbaine is offline
Old 11-04-2013 | 01:49 PM
  #10983
Wildcat1971's Avatar
Tech Prophet
Lunsford. Lifetime warranty against bending or breaking.
Wildcat1971 is offline
Old 11-04-2013 | 02:36 PM
  #10984
Thanks, Wildcat. Good to know. Lunsford it is.
Old 11-04-2013 | 02:55 PM
  #10985
Jstall7543's Avatar
I like and run all of those and you can't really go wrong. I went with the jc fins just because they were a new look that I like.
Jstall7543 is offline
Old 11-04-2013 | 04:41 PM
  #10986
bilster44's Avatar
I called and spoke with their tech guy...he said if you use a regular thrust, the steel balls may have a chance of slipping out and scouring the inside of the aluminum outdrives.
bilster44 is offline
Old 11-04-2013 | 06:10 PM
  #10987
Flip boy's Avatar
Can any of you guys weigh in on using the puck system with a 13.5? I am curious if thats too much power?
Flip boy is offline
Old 11-04-2013 | 06:38 PM
  #10988
Jmuck69's Avatar
Not for their hingepins! I bent one in my old DEX 210 and they told me I was SOL!
Jmuck69 is offline
  #10989
Pittsdriver's Avatar
I am almost done getting my B4.2 together. Just need to paint and cut the body, then I can begin some shakedown runs. Are there any hot tips from the experienced guys as far as weak points on the kit that I should take care of right away? I did RPM ballcups already. One thing that made me nervous is that I feel like I couldn't tighten screws down as tight as I would want, and might have even stripped some threads in the plastic. Is that a common problem on the kit?
Pittsdriver is offline
Old 11-04-2013 | 06:55 PM
  #10990
Jmuck69's Avatar
Be careful of the rear brace and shock tower bolts that go into the chassis. They seem to strip out first.
Jmuck69 is offline
Old 11-04-2013 | 07:02 PM
  #10991
Regarding the MIP puck stystem, I am using the AVID caged (Ceramic) thrust ball assembly in my (MIP/Puck) setup & have no issues at all. The diff (with AVID Carbide 3/32 diff balls, is smooth and after a thorough break in, still strong without the need to tighten it. The Puck system was a huge difference in weight & acceleration, well worth every penny. I have at least 10 race days on the first set of orange/plastic pucks & the out drives & pucks still look like new.
desertracerdad is offline
Old 11-04-2013 | 07:03 PM
  #10992
rc car guy's Avatar
dont wrench it on it, its plastic the only screws that i have strippe are the rear brace and those both happened on different runs, so ya but other than that dont wrench on it just snug it
rc car guy is offline
Old 11-04-2013 | 07:07 PM
  #10993
Jmuck69's Avatar
So I shouldn't tighten them with a power drill? Damn...thats what I'm doing wrong.
Jmuck69 is offline
Old 11-04-2013 | 07:08 PM
  #10994
rc car guy's Avatar
no thats why i stopped using one cept for taking stuff out i hand tighten everything ...
Old 11-05-2013 | 06:00 AM
  #10995
vfrninja's Avatar
Originally Posted by Grasschopper
Not sure why people keep saying $90 for the Pucks system...MSRP maybe? AMain has it at $68...which still isn't cheap but it isn't $90 either.
It's not for mod racing...don't use it in a mod car, the mod car has plenty of power to spin up the drivetrain, the 17.5 being "power limited" gains a benefit from the lighter drivetrain.
I would think that money spent on the puck system would be good in the long run. Ae outdrives aren't cheap and wear really fast.
vfrninja is offline
