Team Associated B4.2 Thread >
Like Tree4Likes
Old 12-10-2013 | 07:29 AM
  #11731
lodhammerdin's Avatar
Originally Posted by Autocratic
Schumacher makes some really nice hard coated aluminum pinions. I mainly have those in 17.5 sizes, but they're very quiet and don't wear.
The nicest Pinons on the market are the xray ones, if you can afford to shell out $20 on some every time you need one. I won a set (15-36) a year or so ago at a race raffel. One of these pinions with a JC SS spur gear and my car makes no noise.
The Schumacher ones are pretty nice too as well as these ones. Link is to amain hobbies.
lodhammerdin is offline
Old 12-10-2013 | 07:32 AM
  #11732
Originally Posted by derbrylac
less anti squat-more side traction in corners
more rear traction for slick or bumpy surfaces
more anti-squat less side traction in corners
more rear lift in jumps
I would suggest leaving #1 anti squat there or even use shims to get 1.5 anti-squat.
Thanks. What I plan on doing is going this weekend and running 5 minutes runs and changing the shim each time, from stock down till o have none in. Thanks again.
Old 12-10-2013 | 07:37 AM
  #11733
Autocratic's Avatar
I have a good amount of the PRS pinions as well. Very nice.
I wish CRC made the gold lightweight pinions in 48p. Best 64p pinions ever.
Autocratic is offline
Old 12-10-2013 | 08:04 AM
  #11734
Bcholka's Avatar
Thanks for all the great info on the pinions guys!!!
Bcholka is offline
Old 12-10-2013 | 08:11 AM
  #11735
racer1812's Avatar
Super Moderator
The hard Ano Robinson pinions last longer than you might think. I can get a full season out of them in mod 2wd. I'm sure the high dollar ones are better but the Robinson's would let you know if going to aluminum would be worth the investment.
racer1812 is offline
Old 12-10-2013 | 09:59 AM
  #11736
rc car guy's Avatar
I run those and I have been running hem for about 7 years the one did get a rock in it but it still works just a bit chewed up
rc car guy is offline
Old 12-10-2013 | 12:59 PM
  #11737
Jstall7543's Avatar
The losi hard anodized chamfered pinion gear are about $6 each. Try one out, I guarantee you'll like them. Silent operation and no wear so far after 10 packs in indoor clay. They are my new favorites because they are super light!
Jstall7543 is offline
Old 12-10-2013 | 02:13 PM
  #11738
Waflet's Avatar
Hideeho
The last rrp al pinion I trashed was about 8 months old & in almost perfect condition. I let my kid set my gear mesh because I was in a hurry & didn't check it. He set it to loose & it was trashed after a 10 minute run (still usable, but only in the most dire emergency). As long as you pay attention & set the mesh right they will last as long as any other aluminum part.
Waflet is offline
Old 12-10-2013 | 02:22 PM
  #11739
racer1812's Avatar
Super Moderator
little fyi..Aluminum pinions work fine, and for a long time..
IF, they're hard Ano (not sure you can get anything else now), you run a gear cover (who doesn't) AND you run indoors with relatively low dust. I tried one outside on an average dry, dusty track...It lasted 5 minutes, taking the spur gear with it. Not stripped but it was nothing I would use or keep running.
Actually I don't like any pinion that's not hardened, aluminum or steel. I'm sure the Losi's are and I run the RRP Absolute pinions. The $3 plain steel RRP ones (you can tell because they're shinny) are absolute (no pun intended) JUNK.
Old 12-10-2013 | 04:15 PM
  #11740
trixter91's Avatar
I have a 3 degree rear tow block if I changed to 2.5 degree what difference will my car see.
trixter91 is offline
Old 12-10-2013 | 05:09 PM
  #11741
CHIZZLE's Avatar
Less rear toe.
CHIZZLE is offline
Old 12-10-2013 | 05:13 PM
  #11742
Now for a more meaning full answer... Decreasing toe in the rear will decrease traction in the corners. basically if you are looking for more rotation (controlled) off power and on power decrease the toe angle
It also accelerates a little quicker and has less friction while running WOT
jdeadman is offline
  #11743
trixter91's Avatar
Originally Posted by CHIZZLE
Less rear toe.
No crap
Old 12-10-2013 | 05:15 PM
  #11744
trixter91's Avatar
Not tire angle the block in the rear.
Old 12-10-2013 | 05:16 PM
  #11745
CHIZZLE's Avatar
No crap
Sorry buddy. Just playin with ya.
CHIZZLE is offline
