Tekno RC EB48 Thread
#7246
#7247
#7248
#7249
#7251
Again a recommendation is a little bit of oil (honestly does not matter what time, shock, diff, full scale car heh) on the screw. It will thread and tap much easier with just a small amount of reduction of friction.
#7252
First race, second place. Before the race I only drove two battery packs on local track, and 10 minute run on the race track.
Tekno performed flawlessly.
BUT! The center shaft wobble got worse. I really hate that, sorry to say, but it is very annoying that such bad quality center shaft is spoiling the whole otherwise great car.
Foto taken from Liporacer.at photo by Michi on their FB page. Thanks to all our new Austrian friends! Second photo is from our successful Slovenian Team first visit, each of us got place on the podium.
Best regards to all, new Tekno fan Miha :-) (hating the center shaft bad quality though!)
Tekno performed flawlessly.BUT! The center shaft wobble got worse. I really hate that, sorry to say, but it is very annoying that such bad quality center shaft is spoiling the whole otherwise great car.
#7253
Those couple of screws are quite tight as it's a long thread to tap unless you're using some sort of power tool.
#7255
As far as center shaft wobble are you using the stock steel or lightweight aluminum one? My aluminum one is wobble free on both my eb48 and sct410. If you were local I'd give you my stock new ones for free to try to help your wobble issue.
#7256
As a running change I put the aluminium shaft in my second build. I don't really have an issue with the steel one in the first car but wanted to give it a try. I'll put one in the first car too one day.
Space and tolerances are tight in this chassis (a big difference to most other cars, like the Vorza I was used to) so it's surprising that this wobble issue wold exist. There is not much wiggle room against that shaft in places.
#7258
Today I bent an aluminum shaft so bad it will no longer work as is after what appeared to be a minor cartwheel today. I assume the chassis flexed a little too much (running front and center braces) during said cart wheel and bent the front aluminum drive shaft. I'll try to straighten it out and see what happens or if it holds up, makes me wonder if anyone else has experienced this or if anything else is wrong with it?
#7259
my aluminum center shaft wobbles more than my stock steel shaft. I think its just so long that even the slightest bit of bend throws it out of whack. This might sound stupid, but I was wondering if the long hollow aluminum shaft for the traxxas 4x4 slash could be modified to work. Just a thought. I havent measured anything to see if its even close in length. Not sure what traxxas is doing but the center shaft in the 4x4 slash runs perfectly true.
2Likes
Do it by hand and I guarantee about 2/3 of the way putting those screws in your hands start to cramp up
