Like Tree1Likes
Novarossi Vir-tus.21
Old 05-12-2013 | 09:44 AM
  #61
Hi guys,
Normally a 500cc bottle is about right. However I found with the new Virtus, you need more time for the break in. If you only use 1 fuel bottle it will not be ready to perform at its best. I would go through the first bottle really on the rich side. Keeping it around 190-205 degrees. For the second bottle keep it around 210-220. Always run the bottom rich in this process as well. One the 3rd bottle you can start running it with a rich race setting. By the fourth bottle you can run it full out.
This is just what I found when I did my first ones.
DJ Apolaro
dj apolaro is offline
Old 05-12-2013 | 10:01 AM
  #62
Do any of you use the included venturi restrictors? If yes, any recommendations which one to use?
alexlok is offline
Old 05-13-2013 | 12:12 AM
  #63
Originally Posted by dj apolaro
Hi guys,
DJ Apolaro
Thanks DJ for your advice. Just to clarify, when you say the third bottle is run with a "rich race setting" do you mean to still run it rich? Or can start to lean it out for a race setting?
alexlok is offline
Old 05-13-2013 | 05:57 AM
  #64
You are definitely leaning it out for racing but just running it on the safer side a little rich. you are not running it on the extreme side yet.
Dj
Old 05-13-2013 | 06:16 AM
  #65
choisan's Avatar
can someone kindly advise what are the sizes of both front and rear bearings?
choisan is online now
Old 05-13-2013 | 07:21 AM
  #66
I believe standard 14.5x26 and front would be 7x19x5
But the main bearing is different in shape that a normal bearing would not fit.
Roelof is offline
Old 05-13-2013 | 09:23 AM
  #67
choisan's Avatar
Thanks. This is why it scares me away since Flash, the bearings are very expensive and proprietary. I would go for something easy.
1/8 is difficult to get popular now a day. For a beginner, it is easy to spend at least $2 to 3000 US to be competitive in terms of gears.
Old 05-13-2013 | 02:19 PM
  #68
Up to the flash it is a very normal bearing you can find at TKO, Boca etc. for much better prices. The keep-on and the Virtus has a small edge in the cranckase and need to fit a bearing with a smaller (in width) inner brace. Handy people can mill out the edge from the crankcase and fit a normal bearing. I truly believe this has no real technical function than only protecting their after market in bearings.
But probably other RC bearing manufacturers have made a ready to fit bearing for these latest model engines. Just look arround.
Roelof is offline
Old 05-13-2013 | 04:39 PM
  #69
choisan's Avatar
Thanks, milling is not the option to buy it
Old 05-13-2013 | 11:18 PM
  #70
Hi guys,
DJ Apolaro
I just got a Keep On Break-in. So do I still have to break in 500cc bottle?
victor1997621 is offline
Old 05-14-2013 | 05:28 AM
  #71
Yes, the same procedure for all the Nova factory broken-in engines.
desotoracing is offline
Old 05-14-2013 | 05:34 AM
  #72
Yeah, the Keep-on I just do the 500cc bottle and by the end of it, I am ready to lean it for racing.
DJ Apolaro
Old 05-14-2013 | 05:04 PM
  #73
occ
Can someone advise me on the different models of the Vir-tus?
Correct me if I am wrong but is the following what we can buy:
1: Rear ceramic bearing
2: Front and rear ceramic bearing
3: Pre-break in rear ceramic
4: Pre-break in front and rear ceramic bearing
Any more models?
occ is offline
Old 05-15-2013 | 04:20 AM
  #74
Default VIRTUS RED DOT
I heard about a Vir-Tus .21/S red dot version. what the difference between the regular one and the red dot team engine? thanks!
jusandsil is offline
Old 05-15-2013 | 07:08 AM
  #75
Where can we buy the red dot engine?
