Tekno RC EB48 Thread >
Like Tree2Likes
Old 05-01-2013 | 02:56 PM
  #6076
brian94066's Avatar
But whips are fun!
brian94066 is offline
Old 05-01-2013 | 03:59 PM
  #6077
JEFFs SC10's Avatar
What is a whip?
JEFFs SC10 is offline
Old 05-01-2013 | 04:42 PM
  #6078
Originally Posted by JEFFs SC10
What is a whip?
do sth before the jump, let the car turn in the air, and land sideways so that you can skip the process of braking and turn in, pretty go straight right after landing.
according to this study: https://www.youtube.com/watch?v=KSB_9KE6fWI , quick turn in and quickly gain the angle for exit is the faster way through the corner. Imagine turn in in the air.
with my limited knowledge and experience, all I know is to get a bit more than enough speed before take off, turn and brake a bit to initiate the turn-in, and the car will keep on turning while in the air. The difficulty is to keep the balance and angle correct in the air, and to land almost perfectly o/w result will be worse.
for example:
http://www.youtube.com/watch?v=kDk-2b8LzuM&t=14s
and this race:
https://www.youtube.com/watch?v=1-e_d7x_XBo
nicholasxuu is offline
Old 05-01-2013 | 05:15 PM
  #6079
cmunro's Avatar
i ran my buggy yesterday for the first time with the stock setup and it under steers every where what should i change to get more on power steering?
cmunro is offline
Old 05-01-2013 | 05:34 PM
  #6080
brian94066's Avatar
check dis yo
+ YouTube Video
Old 05-01-2013 | 06:03 PM
  #6081
RC*PHREAK's Avatar
Originally Posted by brian94066
check dis yo
+ YouTube Video
i hate that kid...
RC*PHREAK is offline
Old 05-01-2013 | 06:53 PM
  #6082
Rockthecatbox21's Avatar
Originally Posted by RC*PHREAK
i hate that kid...
Austin blair or jang?
I could see how "whipping" could save a little bit of time, but i'd imagine it come at a cost of excessive tire wear. Especially on a high traction track like that. But full-ride chassis sponsored drivers don't have to worry about the cost of a set of tires. (austin blair, ryan lutz, ryan mayfield, adam drake, etc.) For me, i wouldn't want to risk crashing while trying to show off. Unless i have a huge lead, i'm not gonna be whipping in the middle of a race.
Not even the superfast drivers @ my track do whips.
Rockthecatbox21 is offline
Old 05-01-2013 | 06:55 PM
  #6083
Default picked up a used one...
I was wondering what are the stock shock oils for the buggy?
Any suggestions on the stock pistons and stock springs for a 4s 6400 pack? The current set up is so soft... Thanks.
Tmachine is offline
Old 05-01-2013 | 07:02 PM
  #6084
brian94066's Avatar
You can land shorter so it allows you to hit the jump quicker
You can also enter corners right after jumps a lot quicker by setting up in the air and land the right way instead of land then turn
If you learn how to countersteer or whip in the air you can correct your car's attitude in the air allowing you to hit jumps with a bit less care and still land the right way
In the end it's just cool
Old 05-01-2013 | 07:05 PM
  #6085
3Captain's Avatar
Just placed my order! They look great and should save some hassle when building the shocks! Thanks Chris!!
Originally Posted by ChrisAttebery
Hey Guys,
It's been a while but I finally finished another batch of Tekno shock tools. They are at the anodizing shop now and will be ready to ship on Friday. They are available for pre-order on the web store now.
I made a couple changes to the design. I removed the small ridge around the perimeter to make them a little cleaner looking and less harsh on the fingers. I also opened up the smaller 17mm hex by a couple thousandths.
Thanks,
Chris
3Captain is offline
Old 05-01-2013 | 07:08 PM
  #6086
RC*PHREAK's Avatar
i was just kidding. i don't hate either. austin is a nice kid.
as for whips, yeah, sometimes he does it excessively to put on a show, but most of the time, whipping sets you up for after the jump. if all jumps led to straightaways afterward, whips wouldn't be necessary, but often there is a turn soon after a jump and if you can whip the buggy so it lines up better with the upcoming turn, you save time (i don't buy that whipping scrubs speed). austin is the master of this.
Old 05-02-2013 | 06:17 AM
  #6087
Getting ready to place a big parts order with Amain and am still undecided about springs. What springs should I have for this buggy and what spare parts do I need to have. Thanks.
JoeC is offline
Old 05-02-2013 | 07:22 AM
  #6088
cpt_RedBeard's Avatar
haha, same answer from over on the SCT410 thread. I run the exact same shock setup on both.
cpt_RedBeard is offline
Old 05-02-2013 | 07:35 AM
  #6089
I would be interested in hearing some setups to increase turn-in speed on the EB48, it seems a suffer from under-steer (on & off power). This is for a 1/10 scale size track that is relatively tight and is most likely not an issue on a 1/8 scale sized track.
jpas is offline
Old 05-02-2013 | 07:54 AM
  #6090
Cain's Avatar
Have you played with the toe in settings at all?
Cain is offline
