Tekno RC EB48 Thread >
Like Tree2Likes
Old 04-30-2013 | 08:44 AM
  #6046
Originally Posted by MX304
Be very careful with that on Hobby Wing motors. Most, if not all, of their motors that are pre-wired cannot have the wires changed or shortened. The motor leads are part of the actual windings. I burned up two motors doing that before I figured out what the deal was.
I cut and soldered new wires on my xerun 2200 inside the can without issues.
Maybe the motors vary.
jonasm48 is offline
Old 04-30-2013 | 08:50 AM
  #6047
BashemSmashem's Avatar
As long as you keep the leads the same length shortening the motor wires shouldnt be a problem . I have done it to several Castle motors with no problems , just make sure the motor wires cannot touch and short out .....
BashemSmashem is offline
Old 04-30-2013 | 09:08 AM
  #6048
Problem is the second I desolder the wires, I void my warranty. For now I'll just have to get creative and deal with the excess wire. Not happy about it, but oh well, absolutely can't argue with the price I paid for the combo when comparing it to the other options out there. Gotta sacrifice something, at least it's not performance.
Hinecken is offline
Old 04-30-2013 | 11:44 AM
  #6049
ChrisAttebery's Avatar
I tape the batteries together in that staggered configuration. There is a small piece of foam under the front of the lower pack to keep it from moving forward.
I've been running my EB48 like this since last June and I haven't had any problems with the batteries moving around.
When I run 2 shorty packs my car is 7lb, 2 oz. My track does not require a minimum weight for ebuggy.
Originally Posted by Cain
for you battery setup, are you using a spacer or some sort of guard to keep the top back from sliding into the bottom ones wires?
SNIP...
So, here is my question
For those running the vehicle in a 2S configuration, what is the running weight you are seeing assuming heavy electronics and what mods have you done recently to make minimum weight if you track requires it?
I am considering doing this with my EB48, set it up basically the same as my SCT410 but use the Tekin HD motor of something similar in power, can then just fully standardize on one battery type.
ChrisAttebery is offline
Old 04-30-2013 | 11:57 AM
  #6050
http://radiocontrolzone.com/showthread.php?t=268782
Okay Tekno, time for you to give us an E-Truggy too!
And a 1/10 2wd buggy.
And a 1/10 2wd Shortcourse
And a 1/10 4wd buggy!!!
Antimullet is offline
Old 04-30-2013 | 12:21 PM
  #6051
brian94066's Avatar
I vote 2wd buggy
brian94066 is offline
Old 04-30-2013 | 01:00 PM
  #6052
justpoet's Avatar
Originally Posted by brian94066
I vote 2wd buggy
I just took a break from mine so I could pick up my 4wd buggy. But if Tekno released one, I might just have to get back to 2wd buggy sooner rather than later.
justpoet is offline
Old 04-30-2013 | 01:06 PM
  #6053
moto44's Avatar
Just ordered a EB48. What size motor should I run in it? I am running 4cell and have a Viper VX8 for it and trying to decide whether to get the Tekin 1900KV or the Tekin 2050. I drove my friends Mugen Eco with a Tekin 1900 KV and it felt like it didn't have that much punch to it. It could be the way he had it set up I guess.
moto44 is offline
Old 04-30-2013 | 01:07 PM
  #6054
Cain's Avatar
Tech Legend
wheeler would be cool. Just need to get people past the stigma of "breaks if you look at it wrong" with more durable vehicles and maybe a class that is not full on mod.
Cain is offline
Old 04-30-2013 | 01:11 PM
  #6055
Cain's Avatar
Tech Legend
If that is how it felt to you, you probably would like the Tekin 2050 then. I use that motor and it has a lot more pop to it. The 1900Kv is a good motor though, just really depends on what you like.
Cain is offline
Old 04-30-2013 | 04:18 PM
  #6056
It was enough punch for this guy...
http://www.teamtekin.com/2012-ROARSuperNats.html
"All of the Amain Tekin powered drivers utilized the Tekin Rx8, Tekin T8 1900"
I have driven both in the same setup (eb48) and they feel about the same. The 1900 seems to brake better and is more flexible with gearing.Keep in mind the center diff oil makes a big difference on how punchy the motor feels.
I tend to think wye (1900) wound motors are a better choice than delta (2050)because they are more efficient because the poles don't oppose each other as the motor spins. You should get about 7% more battery life out of a 1900 which works out to about 1 minute on a 4000mah battery.
james633 is offline
Old 04-30-2013 | 05:48 PM
  #6057
Genebaby's Avatar
I am happy so far with my T8 1900 and Viper VTX8 setup. It's quite conservative on mah.
For 7min races last weekend I was using 1500mah.
Genebaby is offline
Old 04-30-2013 | 06:36 PM
  #6058
cpt_RedBeard's Avatar
You also pee sitting down! 2650!!! Go big!!! Lol
Just Kidding. A lot of the local fast guys run a 1900 because there's a little less wheel spin.
cpt_RedBeard is offline
Old 04-30-2013 | 06:42 PM
  #6059
JEFFs SC10's Avatar
On.a.scale of 1 to 10, what is the fun factor.driving one of these?
JEFFs SC10 is offline
Old 04-30-2013 | 06:43 PM
  #6060
Matt Howard's Avatar
11, there's nothing that matches driving a good 1/8 E buggy
Matt Howard is offline
