Tekno RC EB48 Thread
#5896
i agree with everyone on all the esc mounting comments, and with that being said i still think its about time someone made something that is the ULTIMATE in mounting electronics. wheres that techy nerd engineer with the solution!?!?! lol we can make these sweet platforms but can't make a sticky pillow??? hahahaha
#5897
See know your scaring me. I put a lot of stock in that Kyosho zeal tape. Thinking my RX8 were indestructible. Looks like I'll never go for that quad quad again lol. I do think that is about the very best you can get right now, until i figure out how to shoe goo some feathers together neatly.
#5898
tempurpedic servo mount tape and pretty thick.......someone could make a lot of money and save esc's.......i dont know why someone hasnt developed the ultimate esc mounting pad. i even have had rx8's go out using the kyosho zeal tape. a couple actually. it just needs a nice comfy pillow that wont move to much and not transfer energy on impact. someone make it for crying out loud!!! lol
http://www.elkproducts.com/product-c...-mounting-tape
Personally I use the Parma servo tape, but I double it up under the ESC.
#5900
Also, has anyone used this to mount the receiver in the box? Or should I still use foam like done with 8th nitro buggies?
#5901
I use the zeal gel under the receiver in the box as well, works like a charm...no more brownouts when overshooting big jumps.
#5903
The zeal tape and Parma clear tape all work fine. To be honest I've had mine screwed down directly onto the plate without issues.
It's not always the shock of the landing causing a physical issue on an Rx8 failure. It can often be an issue with servo back feed,etc.
The servo's we're all running now have had HUGE gains in performance. These "gains" have to come from somewhere and most are from power consumption. That means from the Rx8 most of the time.
Some servos cause more issues than others. If you're not sure, ask over in the Rx8 thread and I'll be happy to help you out.
#5904
On Saturday I could hear a crunchy noise during that 12 minute main. I thought I had picked up a rock between one of the arms and outdrives. That's happened to me a couple times in the past after a few minutes it went away. Last night I was cleaning the car up and noticed that there was a lot of dirt around the center diff. On closer inspection it wasn't dirt but ground up metal. Then I noticed the pinion...
Hmmmm, maybe that was the problem.
Luckily the steel spur looks fine. I think I may have set the mesh a little too loose.
#5908
#5909
Mod 1 pinion 0
I do think it really helps out the the ESC is mounted forward in the chassis for the EB and SCT. My old SCTE ate a couple of ESC's. With them being mounted toward the rear and all. No way the chassis slap was helping them live longer
#5910
I was cleaning my buggy and just noticed the bearing on the rear diff pinion, on the outside of the gearbox is messed up and of course the pinion shaft is wobbly as a result. I've only run the buggy twice. Is this bearing of any other bearing on the kit prone to breaking? Also, are there any other bearings that would work because if possible, I'd like to get one from my Lhs and I know they don't have the tekno ones?
2Likes
