Team Associated B4.2 Thread
#4351
#4352
I run on fairly low-bite outdoor dirt tracks. What has been working for me is as follows.
Front
Shocks: 1/0
Link: 1A
Washers 1 blue 2mm washer
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Green
Oil: 32.5 2x1.6
Camber: -.5
Limiter: 3
Rear
Shocks: 1/I
Springs: White
Oil: 30 2x1.6
Link: 1/B, C HUBS
Washers: Shaved brace 0 washers
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: -1/2
Limiter: 2
Ride: 23.5
All Plastic Parts. 0.5 Degree Rear Hubs, Wolfpack Shorty with center mount esc. Shorty Pushed forward with 14g behind servo. Full ballast under tranny mount. Running 8.5 with 24/81 gearing
Would love to hear suggestions on a better setup. So far this works fairly well; however if I touch the throttle at all on corner exit it wants to swap ends.
Front
Shocks: 1/0
Link: 1A
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Green
Oil: 32.5 2x1.6
Camber: -.5
Limiter: 3
Rear
Shocks: 1/I
Springs: White
Oil: 30 2x1.6
Link: 1/B, C HUBS
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: -1/2
Limiter: 2
Ride: 23.5
I started with about your setup, but have switched to Green Rear/Black Front (V2 springs). Also running A hub with no washers for higher roll center in the rear. Rear seems to break a little more predictably.
The trade off with rear roll center is corner rotation (higher rc means easier rotation), so I'm planning to try higher front RC, brown front springs (for more turning) and lower the rear RC (more washers). Hoping to add steering and limit rotation at the same time. Basically the Hartson setup for Motorama (on AE website).
Outdoors on real dirt is so much more fun! Conditions changing all the time!
#4354
Well, now that I reread it, both are correct. Just depends on what part of the turn you're referring to.
#4355
Regarding pistons:
Stated: piston/total dia/total area
2x1.5 = 3.0mm = 3.53mm
2x1.6 = 3.2mm = 4.02mm
2x1.7 = 3.4mm = 4.54mm
3x1.4 = 4.2mm = 4.62mm
4x1.3 = 5.2mm = 5.31mm
Still testing and trying to match my fluids accordingly for track conditions...
(So there is no confusion, now stated as total area of holes as well.)
#4356
Just try it all out and see what works for you, IMO. I learn the most just experimenting on practice days messing with tires suspension etc. and not dwelling on that fact that my setup doesnt match a pro's setup.
Side note: A bunch of people on here are complaining about the 1.6 pistons as an example and I couldn't be happier with them. Don't knock it till you try it. Going to try the 1.4's this weekend as well.
EDIT: to AE Matt above, I think a more accurate comparison would be the hole areas added together, and perhaps the circumferences added together as well because that's the surface where 'sheering' occurs.
#4357
Regarding pistons, I also consider the combined total hole diameter for each:
2x1.5 = 3.0mm total
2x1.6 = 3.2mm total
2x1.7 = 3.4mm total
3x1.4 = 4.2mm total
4x1.3 = 5.2mm total
Significant difference between the 2 hole and 3 or 4 hole pistions. Still testing and trying to match my fluids accordingly for track conditions...
2x1.5 = 3.0mm total
2x1.6 = 3.2mm total
2x1.7 = 3.4mm total
3x1.4 = 4.2mm total
4x1.3 = 5.2mm total
#4359
#4361
#4362
why do people keep adding the numbers? IMO, the math means nothing. You have to try them. I really like the pack of the 1.4x3 for my track. It also seems to soak up the rough parts better and the corning is much more balanced and consistent for me. Put the calculator away and drive.
#4363
That is fine aeMatt. But adding up the diameters is pretty useless. Smaller holes more pack. more holes more pack. That is the easy part of it. Now how the numbers and size of the holes effect corning is just something you need to feel. Math wont tell you how a 1.4x3 will feel on your track in the corners to you. Sadly everyone wants a quick answer, so they can spend the least amount of money. And I can understand that, but nothing at all beats practice and testing. I love the 1.4x3's some people really like the 1.7's or 1.6's. The funny thing is with the V2's everyone ran #2's pretty much. With the Big bore shocks, drivers seem to find more differences in the feel. I have not tried the 1.5 + 1.1 avids yet, but for me the 1.4x3 feel great on my home track. I am told the avid's and the ae non machined can be changed without removing the shaft from the body, so its pretty easy to do the changes. My machined AE 1.4's are a little tight, but I might be able to remove them without removing the shafts also.
#4364
#4365
What will adding a stiffer or softer rear spring do?
I need more rear traction in the corners?
I am currently running Green/green front and rear and I have black and white rear springs to work with.
Thanks!
-Venom
Thanks!
-Venom
4Likes
