Team Associated B4.2 Thread
#4381
Hey guys. Sold my B4.1 last summer and didnt really follow whats been going on with the B4.2. Just got one the other day and looking at upgrades for it.
Is everyone still just dealing with the FT rear hubs? I see exotek makes some but only gives you the option to run the A position. Any other options out there?
I was also looking at the Avid shock standoffs. Really don't like the stock setup of metal on metal. Anyone tried these? If so how are they durability wise? All the Avid stuff I have ever tried has always worked great so I would expect these to be no different.
Any other suggestions on things to look at let me know.
#4382
#4384
Avids are great as long as you don't slide the rear wheel into the wall repeated (ask me how I know
). From what I've seen, exotek makes a good product, but you have found the weakness, a tower only. I haven't seen it in person, but the yaiba hub has everything I'm looking for in a hub. 0* toe, vertical ball stud, c-tower height, add spacers to get a-tower height.
#4387
#4388
They're hauling out the old dirt because it was too high grip/abrasive/hard to work with.
#4391
I run on fairly low-bite outdoor dirt tracks. What has been working for me is as follows.
Front
Shocks: 1/0
Link: 1A
Washers 1 blue 2mm washer
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Green
Oil: 32.5 2x1.6
Camber: -.5
Limiter: 3
Rear
Shocks: 1/I
Springs: White
Oil: 30 2x1.6
Link: 1/B, C HUBS
Washers: Shaved brace 0 washers
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: -1/2
Limiter: 2
Ride: 23.5
All Plastic Parts. 0.5 Degree Rear Hubs, Wolfpack Shorty with center mount esc. Shorty Pushed forward with 14g behind servo. Full ballast under tranny mount. Running 8.5 with 24/81 gearing
Would love to hear suggestions on a better setup. So far this works fairly well; however if I touch the throttle at all on corner exit it wants to swap ends.
Front
Shocks: 1/0
Link: 1A
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Green
Oil: 32.5 2x1.6
Camber: -.5
Limiter: 3
Rear
Shocks: 1/I
Springs: White
Oil: 30 2x1.6
Link: 1/B, C HUBS
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: -1/2
Limiter: 2
Ride: 23.5
RNPNICK,
heres some things to try..
FRONT
inside on tower/out on arm
camber link inside on tower/a hole on hub
2mm bumpsteer
2x1.6 with 32.5 wt ae/green
2 internal limiters this gives u more forward bite coming out of tight 180's cause of the weight transfer to the rear
RAISE RH to 25mm
REAR
inside on tower/inside on arm
3degree inboard toe an 2 degree antisquat block
standard unshaved u brace with 1 shim/ a hole
hubs center/ RUN 0* rear hubs ( the .5 hubs sometimes has a reverse affect an actuallt will make the car get loose..
2x1.6 with 27.5wt
2 limiters/ greens or white rears
Raise RH to 25mm
put 1/4 oz in each rear triangle, plus the ae weight that guess under trans,an 1/20s next to rec..
-Personlly i would go back to the stock speelectronics mounting spots so u get ur chassis roll back an can take advantage of the camber gain..
-0 degree hubs
-try 23/81 or 22/78 to move motor..
But how well maintained is ur car? i mean is the bearing slop, or rear axles binding, diff need rebuilding???
also what speedo r u running cause now adays when brent theike told me when he sent me my speedo to get firmiliar with the different adjustment cause the totally will change ur cars feel, handling, an traction...
is ur EPA,dr,expos set right?
#4392
I did not see that but that is so awesome. Can't wait to see what he comes up with
#4393
Some onboard footage. Mounted my GoPro on my B4.2, it's pretty stable.
http://www.youtube.com/watch?v=j2fo_...rbEI6A&index=2
#4394
#4395
Grass, if you dont care abut the C ub, the exoteks are fine. In either case I would pick up Ti ballstuds for the tubs.
4Likes
probably win another worlds.
