SC10 4x4 Thread
Thus far with the abused Sc10 ...
Found the screws for the front tower were too long and were pushing inside the gear case rubbing the gear .
The gears were installed so the flanges were on the same side & were ground down together making for a mess.
Screws for the gears case were torque down so hard they pushed though and were rubbing the clicker pulley . The counter gear was also rubbing the gear case sides from the same screws torque to tight.
Also had to shim the top shaft so it was tight & not sliding back & forth.
Clicker was so tight ?
It was mash down and now had play so it was rubbing the side of the front gear plate ...
All spins smooth & free now .
Today the rear transmission & shocks ...
Your best solution is not crashing at all when possible.
I consider myself a good marshall and even in Brazil I volunteered to Marshall at times. Even with that said I plan to be an even better marshall when I return to the states this summer.
Have just bit more to go
with the rebuild , the back transmission & VTS were in excellent condition .
Some one else must of done LoL .
This Saturday another Sc10 ( casey) in the battle .
candrell , harley , casey & myself will putting the hurt on the competition .
Can someone watch this video please and give me sugestions why my idler gear is causing so much binding in my gearbox?
Cheers
http://i59.photobucket.com/albums/g2...03C6F194B9.mp4
Cheers
Cheers
Cheers
Sometimes I have had gears that look great to the naked eye but they run like yours. I would change out gears until it goes away.
Its kinda hard to tell from the video. It does look like the gears are in correct but you can double check the manual. Do your idler gear bearings spin nice and free? Do you have any gashes in the transmission case that the gear is hanging up on?
Cheers
Cheers
All 3 gears spin fairly freely until I put the other case half on.
Can't see any damage in case.
It felt like the lip on the idler gear is rubbing on the teeth on the diff but I couldn't shim it out.
Doing my head in!
Doing my head in!
What you are describing sounds similar to the problem I had.
Cheers
Cheers
I just watched the vid full screen. The idler should have a ridge on one side and the ridge side of the gear should mate with the side of the diff that has the screws. In the vid I see teeth on the screw side. Either you have the wrong idler gear or a bad gear from what I see.
5Likes
