Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-09-2013 | 08:45 AM
  #5116
Z-Man.'s Avatar
Originally Posted by houston
14x25.8x6mm
dang monty, give me 10 seconds to refresh the page
Z-Man. is offline
Old 03-09-2013 | 08:46 AM
  #5117
houston's Avatar
Tech Prophet
i was already in the offroad forum zane
houston is offline
Old 03-09-2013 | 08:50 AM
  #5118
Z-Man.'s Avatar
lmao, not bad sir!
also, you coming to the nats warm up?
Z-Man. is offline
Old 03-09-2013 | 09:07 AM
  #5119
Originally Posted by beidle99
I have found that on the older carbs, and most track conditions the 7 is the ticket. If it is a a high traction track and fuel mileage isn't an issue the 7.5 is good
Sorry for being a noob but different venturi sizes are just for more power?
JJ
JJRC is offline
Old 03-09-2013 | 09:23 AM
  #5120
houston's Avatar
Tech Prophet
JJ
think of it as tuning the cfm displacement on a real carb of sorts
a properly jetted engine is most efficient and powerful at the same time
highly recommend the 8mm during first gallon then 7mm from there on out
houston is offline
Old 03-09-2013 | 11:14 AM
  #5121
tony montana's Avatar
Hey guys I went with a p5 at the end of last year. Still have not finished breaking it in yet. How does the p5 compare to the btt's in top end?
tony montana is online now
Old 03-09-2013 | 11:16 AM
  #5122
Maximo's Avatar
about the same ..neither one has much for top end...........
Maximo is offline
Old 03-09-2013 | 11:21 AM
  #5123
houston's Avatar
Tech Prophet
not to make waves but i would disagree , the btt engines have much more top end in stock form than the p5xlt
p5xlt will out perform on short tighter tracks , use 2096/41021 or 2096/41005 in buggy on p5xlt and you will experience happiness
houston is offline
Old 03-09-2013 | 11:22 AM
  #5124
jonw's Avatar
So what stock Nova is better on the top end?
jonw is offline
Old 03-09-2013 | 11:57 AM
  #5125
Maximo's Avatar
Bonito
Maximo is offline
Old 03-09-2013 | 12:15 PM
  #5126
Maximo's Avatar
You may be right on that one ......the last stock P5 I seen run was on a 2058 and it was right in that range of the BTT ..it was actually faster then I expected it to be.....
Maximo is offline
Old 03-09-2013 | 12:29 PM
  #5127
houston's Avatar
Tech Prophet
2013 and 2058 work great on novas given each engine to play with stock for stock you will see the p5xlt is no where near the same on the top end run out as a btt as the btt is no where near the low grunt of the p5xlt
houston is offline
Old 03-09-2013 | 12:40 PM
  #5128
jonw's Avatar
So will you sacrifice low end to gain top end when you go with a Bonito?
Bonito
jonw is offline
Old 03-09-2013 | 02:26 PM
  #5129
prowlag's Avatar
No. The bonito is a beast across the whole curve. Even more so when modded!
prowlag is offline
Old 03-09-2013 | 05:56 PM
  #5130
merdith6's Avatar
Default Yep
what he said. It depends on the track too. I run a plus-4 on a larger track and a p5 on a tight twisty track. The p5 likes the 2096 on a med-large track or low traction, it seems to do better overall if you change the pipe, and a 9853 on short tracks with tight jumps. On the plus-4 or btt etc.. the 9853 makes it snappy even though the btt has a bit more overall power than the plus-4 and should be reeeally fast a bit leaned out like the 2096 seems to want me to do on bigger tracks, but seems to fall short on really technical tracks that are smaller. Usually end up backing it out a little to keep it cooler on a long straitaway so it drops back down going into the corner.
merdith6 is offline
