Like Tree1Likes
JP engines
Old 07-16-2011 | 10:14 AM
  #1111
Originally Posted by desotoracing
No the 35plus uses a smaller front bearing. Here are the part#s for the Eagle:
I know the older 35+ engines do have the 6mm thick bearings as well.
Roelof is offline
Old 07-19-2011 | 10:00 PM
  #1112
tomdex's Avatar
Default JP P-7 L Black
I recently inherited one of these in a Serpent 966 and have run it a few times on the track now . I like the power band, very smooth, and has good runtime around 6mins with 8.5 restrictor. It has the 2015 pipe, with short header.
I have been running 25% Nitro AT Platinum Fuel in it, which I understand is 10% Synthetic Oil only. I use the Nova C7TGC plug.
My background is 1/8th offroad, with OS engines, so I have a reasonable handle on tuning, but not Novarossi style carbies.
With the engine warm, it will idle reliably for maybe 20 secs or more, and pulls away cleanly, with some smoke up into 2nd gear. Our track is mostly tight, with a long straight along the back.
After several minutes of racing, I intermittently experience a 'lean bog' out of one particular corner just 2 bends after the main straight.
I'm assuming I'm a little bit lean on either the top or bottom, but when I richen the either needle ever so slightly, it seems too rich, and won't pull away cleanly or top out properly??
I'm aware the Centax clutch might be causing this, but it operates perfectly elsewhere on the track. This problem occurs only on the same section of the track.
The only other factor i'm thinking about is ambient temps. It has been down around 15 degrees (winter here in Australia) and I've not tried any warmer plugs??
I did try some 20% nitro fuel, but the same was occurring.
Any helpful hints are gratefully received
tomdex is offline
Old 07-27-2011 | 04:17 AM
  #1113
tomdex's Avatar
Default JP 'Lean Bog'
Originally Posted by tomdex
IAny helpful hints are gratefully received
Any ideas??
I'm going to lengthen the Fuel tube from the tank to the carby slighty; maybe I get a small air bubble in the tube via the fuel pickup whilst cornering??
Also going to lengthen the Pressure line, and install a 'Exhaust Gas Cooler' in the line, in an attempt to try and keep the pressure on the tank constant??
Have heard this can be a problem.....
tomdex is offline
Old 07-27-2011 | 04:45 AM
  #1114
Bubles are mostly from shaking fuel. Be sure your tank is mounted a little flexible. If it is screwed be sure the screws are a little bit loose.
Roelof is offline
Old 08-14-2011 | 09:11 AM
  #1115
SOLOARTIST 702's Avatar
Jp 4 ever
SOLOARTIST 702 is offline
Old 02-08-2012 | 09:57 PM
  #1116
Default Identifying a JP Racing engine
hiya..
i have scored a fw-05rr with a jp racing engine in it, but the head screw for the glow plug is stripped.. so looking for a new head.
So first things first.. i need to identify it
so it must be a 12 being efra legal and it has a black crank case with a blue head with JPRacing engraved on the top of the head.. not printed.. the only markings are an R 12 on one side, and an REX on the other... the carb had the middle adjustment screw over and above most normal carbs and is labled with REX sticker on the front.
Next... does anyone know where i could find someone to sell me stuff?
cheers
Stangas is offline
Old 03-07-2012 | 01:09 PM
  #1117
Time to pull the Jp's back out got an 1/8th scale to roll out
Old 03-07-2012 | 08:57 PM
  #1118
TommyBlazin's Avatar
Default FIRST FOR FIRST TIME THIS SEASON
It was a joke how easy it turned over, as soon as the wheel spun that flywheel,with the ignitor, INSTANT success..the eagle 9 team edition, beutiful motor, 1 gallon thru her, selling next week , with a pristine x-ray rx8 if interested pm me tp get the pre sale details.....hate to let either go, but its not a choice i can make at this point, anywho pm me...thanks
TommyBlazin is offline
Old 03-07-2012 | 09:13 PM
  #1119
i think i got enough for now
Old 03-12-2012 | 06:54 PM
  #1120
http://www.rctech.net/forum/r-c-item...m-edition.html
here she is,jp motor and all...
Old 03-20-2012 | 01:59 AM
  #1121
Arahawak's Avatar
Does anybody have a spare JP Eagle R09 crankcase that they want to let go?
Mine was cut by the broken rod..
Arahawak is offline
Old 02-17-2013 | 01:21 PM
  #1122
Default .12 Revolution
Hey all, was working on a friends engine to change his conrod on a .12 Revolution and noted that under the sleeve & crankcase he had a shim to alter the timing (higher sleeve), does it come as stock? since on the exploded view it wasn't showing?
speed6 is offline
Old 02-18-2013 | 02:28 AM
  #1123
JP has done this to many team edition engines, in the normal production lines I have not seen it (so far I have seen)
Roelof is offline
Old 03-04-2013 | 01:25 PM
  #1124
Brand New JPGIMAR R09.1 with GIMAR 2069 Pipe and Manifold.
$850US. Have two avaliable. PM if interested.
JPFX is offline
Old 03-05-2013 | 10:56 AM
  #1125
It's mainly done to get more top speed right?
speed6 is offline
