Like Tree1Likes
JP engines
Old 03-09-2013 | 08:46 AM
  #1141
Roelof's Avatar
Originally Posted by ngracing
how can I measure the combustion chamber? I have to put the piston in the highest position, but the piston is not smooth. Which is the right point to do it?
The solder trick is a good solid methode... Bend a piece of solder into an L-shape and put it through the plughole, turn the engine arround so the solder will be squeezed and measure the thickness of the solder. It must be arround 0.6mm
Originally Posted by SOLOARTIST 702
since were on my favorite subject who knows the difference between the R9s and jp 35 more torque or more rpm
I do not think there is much a difference, only the afterwork and better selected P/S is giving the R09 better performance.
Roelof is offline
Old 03-09-2013 | 10:54 AM
  #1142
Roelof,0.6mm is for engine 2.1cc or 3.5cc?
tq
kyosho malaysia is offline
Old 03-09-2013 | 11:54 AM
  #1143
Roelof's Avatar
That is for the .21 (older models)
Today I have seen 0.5mm although if you are going to build up an engine 0.6 is a very good starting point for every Novarossi. The newer button heads and also the nr8 plugs makes it possible to go as low.
Roelof is offline
Old 03-10-2013 | 05:18 AM
  #1144
Fz
Hi guys, I need a favour. What do you think of Gimar 9.2c ? I can decide either that or latest novarossi virtus .21
Fz is offline
Old 03-11-2013 | 12:23 AM
  #1145
Hi Roelof, which do you think is right distance in a Collari Cordoba Edition? The distance without head shims is 0.35-0.4 (solder trick). Usually I use the engine at sea level. I have thought to up to 0.6, it is right? I can use this distance with OS plugs or only with new Nova plugs?
Thanks.
ngracing is offline
Old 03-11-2013 | 01:39 AM
  #1146
Roelof's Avatar
All Nova onroad engines @25% nitro can use 0.5~0.7 @sealevel. 0.6 is a good starting point using a NR plug 7 or 8. When using the 8 plug a 0.5~0.55 is possible depending if it is a long or short track....
When the engine is at high RPM the flex and play in the whole system does make the head clearance smaller that can blow plugs....
I have seen a person who did get a RB engine from a teamdriver and with running NR7 plugs he constantly blew plugs while the teamdriver running 8 plugs did not distroy them. Adding one shim of 0.1mm did sove the problem without (for him) noticeable power.
OS plugs can be used, I was told the RP8 is a good plug.
Roelof is offline
Old 03-12-2013 | 12:25 AM
  #1147
A friend give me an old, but not use, collari cordoba edition. The engine has 0,35-0,4 mm of head clearance without head shims. But!, it has 0,7 mm of head sihims so 1,05-1 mm of combustion chamber...directly of factory!! Do you thinh it is possible? When I test the engine I felt no power on low range, of course.
ngracing is offline
Old 03-12-2013 | 01:54 AM
  #1148
Roelof's Avatar
That is why I do not trust counting shims, probably his head has a zero gap without shims. Or maybe you were fooled with your head because sometimes there are 1 or 2 thick aluminium shims that tight giving the idea that it is a part of the button head.
For sure 1mm is to much or you must run the hot OS RP3 plugs
Roelof is offline
Old 03-19-2013 | 05:11 AM
  #1149
SOLOARTIST 702's Avatar
jp still good
SOLOARTIST 702 is offline
Old 07-30-2013 | 04:04 AM
  #1150
Still have 2 x Brand New JPGIMAR R09.1 will do for $550US + Freight each. PM if interested.
JPFX is offline
Old 09-02-2013 | 01:27 PM
  #1151
Hello ,
What is the right temperature for Gimar 7.1 ?
Thank you .
Skem61 is offline
Old 09-02-2013 | 02:50 PM
  #1152
Roelof's Avatar
Depending the exhaust and fuel it will be arround 100 up to 120 degrees C
Roelof is offline
Old 09-03-2013 | 02:53 AM
  #1153
The exhaust is Nova 2015 and fuel MLC 25% .
Thank you
Skem61 is offline
Old 10-21-2013 | 03:26 PM
  #1154
Evo 13's Avatar
I can't speak for the 9.2c but I have a Virtus and that baby is a beast; and a mind you, that's in a heavy GT car. And if you don't find that engine powerful enough stock , you can always get it modified to make it just stupid fast.
Evo 13 is offline
Old 12-19-2013 | 01:22 AM
  #1155
RC-Netshop.dk's Avatar
Default www.rc-netshop.dk distributor for JP Gimar :-)
Hi everybody,
We finally got our redesigned shop up and running :-)...
Still many products to come, we got a lot that's not yet inserted.
But at least the shop is running now.
Take a look: www.rc-netshop.dk
RC-Netshop.dk is offline
