Like Tree1Likes
JP engines
Old 07-28-2005 | 04:38 AM
  #391
Thanks hesky and Im2lazy (also for your thoughts on the FW thread) for sharing.
A little off topic here: On the point of 'trigger control' and driving smoothly which affects mileage - do you guys mean to say punch when on the straight and release before it comes to a corner, letting it glide in and gradually increase throttle when exiting the corner? (i have the tendency to blimp/rev before going into the corner and sometimes blimp even during mid corner - that's not necessarily faster right?)
Wow, that's quite a bit to digest and contemplate for now and will try to practice some of these tips at the track this weekend.
Cheers Guys!
coldfusion is offline
Old 07-28-2005 | 05:13 AM
  #392
Hesky's Avatar
I think you know the answer to that, it can feel faster but I guarantee its not! perhaps a different driving style needs to be adopted.
Hesky is offline
Old 07-29-2005 | 09:07 PM
  #393
ok thanks for the tip hesky! will try this driving style later this afternoon and see how it goes.
Old 07-30-2005 | 01:03 PM
  #394
nils's Avatar
Default problem with fx21r01
hello i have problems with my fx21r01 engine,when ussing the jp-efra 2015 pipe and mainfold combo.
after a cople of runs around the track the engine stops with a puf.
but when i use the rd logics pipe combo,then i dont have no problems and the engine keeps running.
can some whone tel me what the problem is.
nils is offline
Old 08-01-2005 | 06:03 AM
  #395
Hesky's Avatar
hi nils, what do you mean by "it stops with a puf"?
edit: I have a feeling the take off on the pipe that goes to the fuel tank is blocked. the 2015 legal pipe should work fine on your fx engine.
Hesky is offline
Old 08-01-2005 | 07:27 AM
  #396
nils's Avatar
hi,hesky its just like i wrote.
when i run a cople of laps ,the engine sudenly stops and the sound that it makes is ,puf or pop and then the engine is off.
the pressuer niple is not blockt,can it not be a problem with the mainfold that it is to short,the mainfold on the rd pipe is longer.
when i drive with the rd logic pipe on i dont have no problems.
but iwant to drive with the jp pipe on the engine.
nils is offline
Old 08-01-2005 | 07:48 AM
  #397
daniz24's Avatar
Regional Moderator
Does your engine produce a heavy smoke? Maybe it's still too rich. In most cases, you will need to lean it more if you changed the pipe from Turbo (6-7mm) to EFRA legal pipe (5mm)
daniz24 is offline
Old 08-01-2005 | 08:02 AM
  #398
Hesky's Avatar
yeah i agree with daniz, if theres no noticeable problems with the pipe, all I can suggest is to have a go at tweaking the mixture. all tuned pipes require a bit of carb messing to get the most out of them ive found.
Hesky is offline
Old 08-01-2005 | 08:06 AM
  #399
nils's Avatar
he,daniz its a 21 engine that where talking of,the 21 r01.
the outlet of the jp is 8mm.short mainfold on
the outlet of the rd logic is 7.5mm,long mainfold on
nils is offline
Old 08-01-2005 | 08:35 AM
  #400
daniz24's Avatar
Regional Moderator
Oops sorry. But does your engine produce a heavy smoke? You can try to lean it out a bit. Do you already check the temperature?
daniz24 is offline
Old 08-01-2005 | 09:11 AM
  #401
nils's Avatar
im back,i was eating down stairs.
no hevy smoke of the engine,temp of the engine 98 c.
nils is offline
Old 08-01-2005 | 09:12 AM
  #402
Hesky's Avatar
When you race 1/10th you only think about 1/10th lol
Still all things the same, i'm sure your carb settings are a wee bit out.
have a play around and let us know how you get on.
Hesky is offline
Old 08-01-2005 | 09:36 AM
  #403
nils's Avatar
i drive 1/10 to,but you should try 1/8 scale it is easyer to drive.
wel guys i wil try some settings with the carb,and wil let you now how it go.
if some whone now what the problem me be please let me now.
nils is offline
Old 08-01-2005 | 07:07 PM
  #404
daniz24's Avatar
Regional Moderator
Yes, I also drive 1:8 scale using Mugen MRX3. Yes it is easier to drive. But I don't love it as much I love my G4's performance
daniz24 is offline
Old 08-01-2005 | 08:04 PM
  #405
Jye
i was just wondering, are jp engines a completly new engine or are the engines based off of novarossi engines?
Jye is offline
