Speed Passion Thread
#2716
Was browsing through some older post and saw mention of the capacitors not having the logic board needing to be replaced on the Reventon line. I just checked all mine and out of 2 R, 2 S and 1 Stock Club only 1 has the new style cap. Message left at the 888 number. I have been running a few of these for about 6 or months and I will say they are the best ESC I have ever driven. Great job Speed Passion.
#2717
What effect would it have if capacitor was bad?on reventon pro, motor seems flat and when i disconnected capacitor the power did not change
#2718
Feeling flat would be more gearing, timing, or profile setup. I would not disconnect the capacitor when running and Reventons.
#2720
No, the capacitor is okay. Just as Nexus said that capacitor is protect the ESC and help the ESC cool down.
#2721
Nope, that is normal behavior for a cap. It holds a slight voltage and that is what you are seeing when pushing the power button. As for feeling flat, what car, motor and gearing are you running? Nail those down and then you can start looking at the ESC although the only thing I could think of would be a really low DRRS (punch) setting.
#2723
thanks for the help!
#2724
As stated above by others, try and connect the ESC to your computer via the programming card. Then update the firmware again. This will usually solve the problems you describe. You can choose any firmware and not necessarily the one you are trying to run. Sometimes choosing a different firmware first helps. Then once your ESC accepts that you can go ahead and update the firmware you are specifically trying to use.
I've tried everything to get it to work that I can think off. Re-installed the latest software on two different pc's and a netbook. Everything works fine but the esc. Now mind you I own two other reventon pros and they work fine and update fine.
#2726
The weight of Reventon Stock Club Race ESC is 82g. Reventon Smart LCD Card is support Reventon Stock Club Race ESC.
#2727
#2729
#2730
Allright, been wanting to try a new ESC and couldn't bring myself to pay for the Orion, so I just bought 2 Reventon Pro's along with a new Sportsman 6.5R. Anything I need to know before hooking them up? Do I need to start with firmware upgrades, etc, or are they good to go out of the box? They will both be going into 2WD mod buggies (me and my son) and if all goes well I may buy 2 more for our 4WD mod buggies.
4Likes
