The AE FActory Team B44.2 Thread
#752
Started my build last night and things were just not feeling right!i am used to 2wd trannies that spin very freely. Some guys at local track say a 4wd feels tighter but mine feels to tight. Should you use the set screws in all cvas?i had two that with the screws in they were binding others smoothe.
Directions don't show installing set screws but they come in the bag.
Any help will be greatly appreciated!
My diffs feel. Good, I used the 6&3 spacers but main cvas still feel tight where it comes out of gear box..
#753
taking out what? the set screws?, ya you don't need them. You can run the set screw and clip together but you have to center the pin EXACTLY when you put in the set screw or it will have a tight spot. I've done it but there's no need to.
#754
My problem is in the front,everything feels good till I snap the gear covers ,the the binding starts,not bad but tight,install screws and it becomes tighter,should I try and space it 5&3? I tried this first but there was about 1/16-1/8. " of play,is this ok or will I burn out gears?
As mentioned, make sure you have trimmed the flashing off the back of the pinion gear and dont overtighten the gearbox screws (they need to be snug, but not cranked down). Its best to tap the threads in the gearbox with a steel screw as the alloy doesnt tap as well and is hard to feel when it is snug.
No need for the setscrews in the CVAs. A small drop of CA on the clip (make sure its at 90 deg to the pin hole, or the CA can jam the pin) and its all good.
Here is the setup I used (transferred the same setup from the 44.1 to the 44.2). I made some changes the standard AE BB setup as our tracks down here in Australia tend to be bumpier and the white springs on the back were way too stiff. Green probably OK for smoother tracks but our straight has some waves in it and the black rear springs helped it to ride much better through these yet didnt bottom over the big jumps.
http://www.keilorrc.org.au/setups/20...unday_Vics.pdf
L8r
Ray
#756
Glad to see everyone else noticed the same thing and it will loosen up during break in. I've paid close attention to detail on my build and so far all the tips on here have been spot on and very helpful.
Tricks I've done:
1. Sanded diff rings
2. 2mm distance from diff cup to spring cover
3. Gorilla tape over chassis at saddle pack location to protect carbon fiber
4. All edges on every CF part sanded & rounded, black sharpie applied and CA sealed
5. Little bit of yamabond in some suspect areas of where screws may back out of the plastic parts they are in (e.g. Screws for A-Arm cotter pins)
So.... Thanks to everyone for sharing your tech tips and insight! Shocks are being started tonight!
#757
I built my .2 last night and noticed the same thing. I had to trim the insite of the case small gear went in. Just a light trim near the bevel edge and it stopped the issue. when the cases were together it would cause the back side of the small gear to rub slightly. A bit of trimming and all was great.
#758
BTW I run a help thread in the Aussie forum (see my sig). If you check out post#4 I have collated my info on the Associated vehicles (will be updated soon to include BB shocks and 44.2). if anyone from this forum wants to ask me a direct question, feel free to post in that thread.
Ray
#759
I spent 2 hours on the front tranny with the same exact issue..... Shimmed according to manual, even tried some different combo's. Soon as the cover went on.... Felt tight. Said screw it and continued on with the build.
Tricks I've done:
Tricks I've done:
Best Regards.
#760
Does anyone have any info on how to setup the f & r diffs? How tight, best way to break in, and so forth. I've done 2wd ball diffs but not sure on a 4wd?
Also are the the piston sizes that come in the kit 1.7,1.6,1.5? I tried getting calipers inside the hole but I really don't get a accurate reading.
#761
#762
Is stamped into the piston just hard to see till you color it.
#763
what is yamabond and is there an other product that do the same thing? because i haven'r heard about "yamabond" here in Denmark
http://www.rockymountainatvmc.com/p/...FQvznAodmjcAGQ
Best Regards.
Best Regards.
Blah --- little confused on this process.
#764
The main point is that the slipper clutch needs to slip before the diff does.
If you have the diffs out of the car and on the bench......take two allen drivers and insert them into the outdrives(to hold the outdrives still). Try to turn the diff gear.....it should be very difficult to turn. If it's not...then diff is deffenately too loose....tighten 1/8th - 1/4qtr and re-check.
Does that make any sense?
