The AE FActory Team B44.2 Thread >
Old 11-17-2012 | 09:57 AM
  #736
Suspended
Sarinexia is offline
Old 11-17-2012 | 11:33 AM
  #737
Suspended
Should I be concerned the rear driveshaft doesn't go in deeper?
Old 11-17-2012 | 11:52 AM
  #738
racer1812's Avatar
Super Moderator
YES!! Something's not right with that.
racer1812 is offline
Old 11-17-2012 | 11:57 AM
  #739
Suspended
I figured it out Racer....
The rear most Center bearing insert was flipped around the wrong way.
No harm no foul . Quick fix.
Old 11-17-2012 | 12:33 PM
  #740
OnRDPassion's Avatar
Originally Posted by dMITIj
would this screw kit be any good for 44.2?:
http://www.amainhobbies.com/product_...teel-Screw-Kit
I am also going to second not going with that screw kit. I used that screw kit on another car and the best thing about the screw kit was the container they came in lol. If you want a better screw kit go with Tony Screwz or lunsford stuff.
OnRDPassion is offline
Old 11-17-2012 | 12:50 PM
  #741
Suspended
+1. Got Tony's sitting in my box.
I'll never buy RC Screwz again. The heads break clear off and they strip just as easy as the kit screws.
Old 11-17-2012 | 01:14 PM
  #742
dMITIj's Avatar
Thanks for the info
Best Regards.
dMITIj is offline
Old 11-17-2012 | 02:26 PM
  #743
racer1812's Avatar
Super Moderator
those who had the .1 and now the .2
Notice any push with the car being +8?
I run the .1 with NO ballast weight, gives better rotation, IMO.
Pro's obviously win with it but for the rest of us?
Kody N. rocked it at Spektrum!
Old 11-17-2012 | 03:33 PM
  #744
rmtr's Avatar
Default Need a little help
Started my build last night and things were just not feeling right!i am used to 2wd trannies that spin very freely. Some guys at local track say a 4wd feels tighter but mine feels to tight. Should you use the set screws in all cvas?i had two that with the screws in they were binding others smoothe.
Directions don't show installing set screws but they come in the bag.
Any help will be greatly appreciated!
My diffs feel. Good, I used the 6&3 spacers but main cvas still feel tight where it comes out of gear box..
rmtr is offline
Old 11-17-2012 | 03:43 PM
  #745
racer1812's Avatar
Super Moderator
diff/tranny will break in, tight now will be smooth after a pack or two.
Don't use the supplied set screw when building CVA's they're not needed. The retainer ring replaces them. A drop of CA to hold them (retainer ring) in place is also a good idea (IIRC it's recommended in the manual as well)
Old 11-17-2012 | 03:44 PM
  #746
rmtr's Avatar
My problem is in the front,everything feels good till I snap the gear covers ,the the binding starts,not bad but tight,install screws and it becomes tighter,should I try and space it 5&3? I tried this first but there was about 1/16-1/8. " of play,is this ok or will I burn out gears?
rmtr is offline
Old 11-17-2012 | 03:45 PM
  #747
rmtr's Avatar
Thumbs up
Thanks Racer!
rmtr is offline
Old 11-17-2012 | 04:20 PM
  #748
rigor's Avatar
If it feels too tight and like it's not exactly spinning free on the CVA coming out of the gearbox, check to be certain you cut off the flashing and smoothed out the back of the drive pinion gear as shown on page 5 step 2 of the manual.
rigor is offline
Old 11-17-2012 | 04:45 PM
  #749
rmtr's Avatar
I took a little of with an exacto,how much is there?
rmtr is offline
Old 11-17-2012 | 04:53 PM
  #750
Jack Smash's Avatar
People do not realize that stanless steel is not desireable for most applications. Softer than the black oxide steel screws that come with most cars. Stripped heads and bent screws are no fun. However your tools will last forever.
Jack Smash is offline
