The AE FActory Team B44.2 Thread
#2251
Racer , UN4 has done great work here .
I have up most respect for his efforts thus far ...
Lets keep this thread informative & fun for all please ...
#2253
Higher inner ball stud lowers roll center.
Lower inner ball stud raises roll center.
If your roll center is too high, lowering it adds traction.
If your roll center is too low, raising it adds traction.
Roll center tuning 101 right here. Try to not get stuck in generalization land.
You just gave the same generalization but more long winded. From my experience, what I stated holds true on high bite indoor clay or low traction outdoor. You said the same but in a more polished but confusing roll center explanation way.
If they realized the error of their ways -- so can you. I have personally found less washers making the rear have way more grip at our track (that is my experience)
but at other tracks, more washers was better. (but you didn't say less grip, you said better. So could be better with less grip and that's what higher inner ball stud does for me. All seat of the pants.)
Carry on, nothing to see here
#2254
Thats why I bought an RC Drift car.
My nearest track is over an hour away, but I have an entire underground parking garage of my apartment at my disposal.
Supposedly CS Drift cars are good for teaching throttle control and brake control.
We will see....
#2255
Originally Posted by Maxxingout
You know what I need.....to play with my rc more! I never get enough track time, once or twice a month don't cut it.
Off Topic.
We will see....
Off Topic.
We will see....
#2257
That's what I said... in a way that's easier to understand than high/low roll center as that usually throws people off. I do understand roll center, I am an assistant in the AP roll center class.
Now... you're gonna call bs, because if you are an ap in a rc class, then you know that I've reduced some grip at low speed in my 2wd. You're right, but overall, the rear grip is far better for this track because we have WAY more out of corner punch situations where we have trouble squaring up than we have slow infield corners, and the infield corners we have need rotation if anything. You will never find somebody wanting grip there in most cases--in most cases, they will say their car is pushing, so the less grip at that point is, if anything, a net gain.
Long winded? Yep. But it has the advantage of helping others understand what is really going on instead of scratching their heads when they lower their RC and then can't exit corners hard on power because their car loops out, but they thought it should have more grip.
#2258
I just started my kit last night also, it seems like the back of the pinion gear is rubbing on the gearbox. So I used a dremel to remove a little material and the pinion is clear now. Its much smoother now with 6 and 3 shims... The rest will break in..
To test it, put the drive shaft with pinion in the gearbox, w/o diff, and spin it. You can feel it rubbing..
#2259
The B44.2 is amazing.
Two months of racing it and I love it. I practice with my B4 much more and save the 44 for race days to keep the tranny and sus fresh. No need to drive this into a wall trying to learn a new track layout.
Using box stock setup and only adjustments are made to the esc and rear wing.
Still using my 44.1 Finnisher(cut at the back with new rear hole) and no one can tell.
I have not tried the ballast in it, but that is my next step in quieting the car down for applying throttle.
Super tough. So far only a spring retainer has blown after diving into a stake holding a pipe down. Did not end my qual. Plus I was able to replace the front two with the next length up and adjust spring collar accordingly.
Only personal gripe is I still a want a composite tub like my b4 or those Lazers out there (...just a personal preference because I can't flow every triple!)
I've been using vrc for about a year now and it is fantastic. Their off road 4x4 truck is similar -enough- to a 4 wheel buggy to give you quality practice without the maintenance or travel costs.
Thumbs up for VRC
-Tommy
Thumbs up for VRC
-Tommy
#2260
#2262
The reason I even pick this nit is because at our track, a higher than "team" roll center has more NET grip in 2wd cars, but a "lower than team" roll center has more NET grip on 4wds. These are my test results from a lot of different cars, not just my own. This is why I shy away from the generalization.
Point taken.
#2263
Welcome. I built mine about 6 weeks ago. I am totally addicted to tweaking and driving it.
#2265
