Like Tree5Likes
SC10 4x4 Thread
Old 11-08-2012 | 10:28 AM
  #31021
Wild Cherry's Avatar
Originally Posted by sneako
I've visited this thread many times and it seems that this kit only works well after lots of time and money.
I run at a track but don't race (TRCR). I have my SC10 and B4 set up pretty well and my SLASH 4x4 gets around without any problems after a little tuning (springs, oil and tires make a big difference). Last time I was at the track I just couldn't get over how quiet the SC10 is compared to any other 4x4 SC!
So, will this truck be a complete let down if I only do minimal tuning? Again, I run at a track, I don't race there. I don't know if I would notice adding a few millimeters of this to that and so on.
I want to build the FT kit and do the same as I have for my other kits - basic set up stuff. Oh, and no saddle packs - I have enough hard case Lipos.
Thanks.
Don't believe you have to buy a bunch of expensive aftermarket parts to make the Sc10 perform ..
No real need for most of those parts .....
Only aftermarket parts personally been using....
RPM arms ($10.50 each set)
Traxxas serrated wheel nuts
3 mm wider offset rims (JConcepts)
Ae Carbon C-brace
Sc4x4 class is way fun and your Sc10 will prove to be very competitive right out of the box ...
Which track are you racing at ?
Wild Cherry is offline
Old 11-08-2012 | 10:35 AM
  #31022
sneako's Avatar
Default ^^^^
Thanks for the tips WC...I figured you would submit a good response. I run at TRCR just like you. Didn't you read my post???
So no need for the FT kit? Just the standard and those upgrades sounds good to me.
>>>>> anyone know the difference in offest between the SLASH 2wd fronts (I run those at all four corners - they widen the stance of the truck a bit) and the offset for the SC10 4x4?
sneako is offline
Old 11-08-2012 | 10:41 AM
  #31023
apologies , miss read post as you did not race at Trcr...
Wish I had a full team kit , no real need for though .
The team upgrade kit from Ae is recommended ....
Old 11-08-2012 | 11:23 AM
  #31024
I recently broke the driveshaft that goes through the slipper xD (using the old slipper). It broke where the washer beetween spring and nut is. What could be the reason for breaking it and how can i prevent it next time?
Cody227 is offline
Old 11-08-2012 | 01:25 PM
  #31025
tlb987's Avatar
What is the difference in the FT sc104x4 and the regular sc104x4 kit? I cant find one the parts are the same except for a few of the parts but what else is there? I hope this isn't a stupid question.
tlb987 is offline
Old 11-08-2012 | 02:05 PM
  #31026
I want to build the FT kit and do the same as I have for my other kits - basic set up stuff. Oh, and no saddle packs - I have enough hard case Lipos. I may even get the original kit and pick up the upgrade package.
Thanks.
I have only been racing since Feb of this year. I hadn't run 4x4 SC since March when I had a SCTE and then I only ran it for a few months. The first time I ran the FT SC10 4x4 a few weeks ago I qualified 4th out of 10 with the truck bone stock running a shortie pack from my 2wd buggy and no weight added. I did tune the truck with my choice of shock oil and other normal adjustments any racer would make. Of course between me choking and lap traffic taking me out a few times I finished 8th but that wasn't the trucks fault. Plus the three guys that qaulified in front of me have been racing since I was in diapers and win with their eyes closed and one hand in their pocket every week. Plus from what I can tell so far the truck is tuff as nails to. So I would say yes you can buy this truck and run it with out having to spend any more money or time running it than you would any other SC. Really though it all comes down to personal preference and driving style. On any given day any of the top brands can win a race. My prefernce just happens to be the SC10 4x4.
roland5color is offline
Old 11-08-2012 | 02:18 PM
  #31027
Cain's Avatar
Opinions vary, as does experiences ...
That said, your track conditions you race on will dictate what you see benefit to as far as aftermarket parts go. So keep that in mind.
Not a stupid question at all.
In my opinion having owned both now, bling mainly other than the chassis brace, sway bars, and VTS slipper setup. the stock kit is actually really good in comparison and can be had really cheap too.
For those wanting to build new, if you do I would highly suggest that you DON'T be the guy who switches vehicles a lot. You will take a bath on it if you do when you go to re-sell. Just a fair warning as right now, the forums are flooded with SC10 4x4s, mainly due to people finding it easier to run the losi, or, I should say, that is what a lot of those who do the switch are saying.
The vehicle I got now off of someone who did just that was pretty much new, and I think in the end cost me about $130 when all said and done.
Cain is offline
Old 11-08-2012 | 04:14 PM
  #31028
JoeGolf's Avatar
I just rebuilt my diffs, transmissions, belt etc, replaced the Castle 3800 which I ran for most of the summer season geared 14/62. Temps were ideal, 130-140(esc 110-120), it just seemed to lack the smoothness I was looking for. Switched to a Pro4 4000 and geared down to 12/62. Temps are running way higher, 165-170(esc 100-110). I would usually gear down to reduce temps, but I'm wondering if I may be under-geared and thats causing the high temps. Any advice would be great, thanks.
JoeGolf is offline
Old 11-08-2012 | 04:21 PM
  #31029
Cain's Avatar
What ESC are you using?
Also, what settings on the ESC?
Where are you topping out down the longest straight?
After your rebuild, how "tight" was everything in comparison to before?
Cain is offline
Old 11-08-2012 | 04:50 PM
  #31030
Think about it ...
Sometimes I see parts that do not work or perform where I race......
Those parts ?
Never get my endorsement...
Old 11-08-2012 | 04:55 PM
  #31031
Cain's Avatar
Think about it ...
Those parts ?
Yeah, but the funny thing WC ...
On one of those parts that didn't work that you observed, I actually conversed with the driver and found out what the issue really was ...
You may want to speak with them again ...
<triple dots off>
Anyone driving an SC10 4x4 out in Michigan? namely this track:
Washtenaw Raceway
+ YouTube Video
Cain is offline
Old 11-08-2012 | 06:07 PM
  #31032
MantisWorx's Avatar
Much easier to just lie about it and make himself feel good!
BTW 8mm mod is for loose conditions NOT indoor high grip, apparently WC doesnt believe AE's head engineers explanation........
MantisWorx is offline
  #31033
Why are we still debating with Wild joke?
Truck's all ripped and ready for the new Portland track's opening. Think I'm running 1.1's instead of 1.2's but i'm going to go with it for the first night.
SC Shaun is offline
Old 11-08-2012 | 06:12 PM
  #31034
MantisWorx's Avatar
I SWEAR I just said the same thing to my self before i made that post
Doesnt really matter, his gig has been exposed by the latest traction rolling vid. We all have bad race nights, its inevitable, just unfortunate we cant see any of his good races.
Old 11-08-2012 | 06:46 PM
  #31035
I know the actual theory of raising the links, but for some reason it has the stated effect for me of reducing the traction rolling on high grip carpet, the first to do this mod was Brian Kinwald on a High Grip track.
http://www.teamassociated.com/pdf/ca...d_Standard.pdf
indybobb is offline
