SC10 4x4 Thread
I had a similar experience with my Brushless hobbies 120a esc and hobbywing 4 pole motor. It just never seemed to have anywhere near the same power as my tekin pro4/rx8 combo even if I added a little boost etc....... Sold the BH esc put in my spare rx8 with the hobbywing motor and even with zero timing I def. noticed a difference in the power change. Not sure how the SP pro would do but the RX8 solved all my issue's...........
Bought the Motor and MMP both new...Truck used
I have been told by others that the Pro4 4600 is to much motor for the SC10 4x4 as well, but not experiencing that myself......
Lastly, how tight should the belt be? If the belt skips I assume you would here it. Is it possible that the belt is to loose and and I just don't hear it skipping? I know in on-road you keep the belt fairly loose, but not sure how tight it should be in off-road.
I'd love to get into on-road, but there's not much of a scene here. I think it'd make me a better driver, as I would have to focus on being smooth while driving at or close to the limit.
I got to watch Hartson run this past weekend, and his truck looked really good (as it should of course). It looked nose-heavy, and the back did rotate coming into the sweeper, but it was VERY controlled. With some quality time, this truck is very competetive. Granted a Losi took the win, but Olson (Losi/MIP) was on a whole different level.
| + YouTube Video | |
The RCSHOX ball diff is awesome. I have been using this diff for a few months with great success. However, I am curious just how tight you should make the nut.
I thought I read that you should tighten everything up as much as possible, so I did that.
But, it would seem, as soon as I got it on the track, a couple laps were really sluggish... there was a lot of drag in the drivetrain. Something would loosen up after those couple laps and all was good. By the way, I run 4 pins, which I learned was the sweet spot for my track and driving.
This happened a few times, after each time I had rebuilt the car and re-assembled the ball diff.
Here's what I don't get. I can't figure out why over-tightening the ball diff would cause driveline drag. Sure, it would make the front-to-rear diff action tight, but not more so than the straight belt drive with slipper cranked down.
Then, last weekend, I ran a flawless first heat. On heat 2 and 3 I developed some sort of overheating problem where the motor got so hot that the solder melted off the connections. Strange thing is that I didn't tighten anything between heats 1 and 2 so is there something else that might have happened? I don't know if this was directly related to any potential ball diff problem, or even if it was a driveline drag problem, but I can't rule it out as a potential source until I understand exactly how the ball diff interacts with everything else.
Leading me to my final question which is: what's a good guideline to remember how tight to make the nut on the ball diff?
have you checked the wear on your pins? Reason I ask is that when discussing with Marcus, the owner of RC Shox, he mentioned that the pins can rotate. So, if say you have a pin that is worn, I am wondering that maybe the actual diff action can change if the pin is worn enough causing one minute for things to feel great, next, too be tighter than you desire.
Now, this may not apply to your issue, but throwing that out there for someone in the know to better respond, especially since you have been using your setup for a few months.
I have been into RC for years I started with a Big Brute and I have had other various vehicles. I have always been a basher. This is my first race truck I bought it as a kit because that's the only way to go in my opinion. I want to try racing this winter. My question is do you really need the clicker I bought an after market pulley and the truck works like the clicker was there. So do I really need the clicker. Help would be appreciated.
Lock it down and forget it's an option.
I agree with the last 2 posts.
MMP is garbage. Exactly as was said, BEC is a fucking joke and the thing is like a chokepoint for current getting from battery to motor.
And don't even consider using the clicker. Mine is permanently glued.
5Likes
