Like Tree5Likes
SC10 4x4 Thread
Old 10-08-2012 | 09:51 AM
  #30241
Cain's Avatar
Tech Legend
Originally Posted by Wild Cherry
Cain , you can go by that set-up advise you like .
I still will be using the advise from my Teammates from Ae ...
You mean like this advice as found on AE's own website?
http://www.teamassociated.com/pdf/ca...HandbookV2.pdf
Adding toe-in (front of wheels point inward) adds
straight-line stability,
while adding toe-out (front of wheels point outward) tends to make the car
wander a little
nuff said.
Cain is offline
Old 10-08-2012 | 10:16 AM
  #30242
If you are haveing problems with straight line running towin dos help but the overdrive Poally makes for abnormal handleing that is ware the diff shines current limiting helps
9turn is offline
Old 10-08-2012 | 10:35 AM
  #30243
What thickness has the big shim-disk under the sun-gear? (4X4 gear diff sun gear washer 91007) Im not sure if it's 0.1mm or 0.2mm :S
Cody227 is offline
Old 10-08-2012 | 10:37 AM
  #30244
fq06's Avatar
fq06 is offline
Old 10-08-2012 | 10:38 AM
  #30245
Cain's Avatar
Tech Legend
the new AE ones are 0.5mm but you remove the shim that goes between the outdrive case and the outdrive.
Cain is offline
Old 10-08-2012 | 10:42 AM
  #30246
Can't be a new one, it has to be beetween 0.1 and 0.2mm thick. But what would you recommend, 0.1mm under the outdrive and 0.4mm under the sungear or 0mm under the outdrive and 0.5mm under the sungear? 0.6mm doesnt work at all and 0.5mm is already a bit tight. (the washers rotate when i turn the outdrive).
//EDIT: how thick are the ones under the planet gears? They were not included in my kit, are they new too?
Cody227 is offline
Old 10-08-2012 | 10:55 AM
  #30247
Cain's Avatar
Tech Legend
not sure what to recommend to be honest as I am using the .5mm setup. I would think that if you got the same basic amount of overall shim thickness by say doubling up on the 0.2 shims under the sun gear and leaving in the shim between the case and the outdrive which (measure, I don't know for sure) assuming its .1mm gives you the 0.5mm setup should be fine. But, maybe there is more to it than that.
The 0.5mm setup new was tight. Will need to drive it in and you may find you will want to rebuild your diffs with fresh oils after that period. I found when I did that on my previous SC10 4x4 the vehicle felt great.
Cain is offline
Old 10-08-2012 | 10:57 AM
  #30248
fq06's Avatar
In all cases there are shims next to the planet gears, no change in size.
.5 is for worn problematic gears. Too tight for new gears.
Two .2 shims under the sun does not really want the outside shim on the outdrive... but you can, will be snug. One .5 under sun will not allow the shim on the outside of the outdrive.
Brand new gears and brand new cases with no woggled out housing should be good with one .2 shim. There are also aftermarket .3 shims if your inbetween .2 & .4.
fq06 is offline
Old 10-08-2012 | 11:40 AM
  #30249
fq06's Avatar
The outside shim will not tighten the gear mesh, it will pull the outdrive out sightly putting pressure on the sun gear shim with the pin keeping the mesh consistent. If you use the .5 shim and the outside shim, there will not be enough space to get the sun gear pin through the hole. That's why AE says no outside shim when using the .5 shim. You need to let the outdrive post move in a hair to then get the pin over the thicker than designed for shim.
Also, like Cain said... not sure what's right for you. Those gears are not exactly machined pieces so some diff builds will vary. Best to dry fit and see how it feels then run it once you feel like it's correct. If your 5k rear fluid feels like 7k or 10k, the mesh is too tight.
Almost always better to start with fresh diff housing so there is no play in the outdrive... especially if you have run it for a while.
fq06 is offline
Old 10-08-2012 | 12:35 PM
  #30250
Wildcat1971's Avatar
Originally Posted by Acill
Just got back from the track after a couple new tuning updates and the first run on the new rear Exotek hubs. These work fantastic. I found that using the 2mm spacer that it comes with and an additional 2mm spacer takes me right to the same height that using the B4.1 rear carbon hub tower I was using before I got them. I'm still using 7mm of spacers in the inner as well. I've also put in 7k diff fluid up front and 5k in the rear with the ball diff and 4 pins. It felt perfect. I ended up taking 3rd in the A-main tonight on a track I only ran once before and had no practice time. This truck is perfect now and I am very glad I gave it the chance it deserves!
And one of my sloppy pit area just for kicks!
lol, I dont even recognize that truck anymore. How is the quality of those hubs? I was thinking of getting the b4 version.
Wildcat1971 is offline
Old 10-08-2012 | 12:49 PM
  #30251
dirtbikekid33's Avatar
I know tow out can give a wondering feel to the car and tried tow in to it also but I'm not getting that feeling anyway I have done countless set ups and like what I have now, but I know it can be better and the only thing I haven't tried yet is to add a good amount of weight on the car which I can make easy and cheap. And yes I want to try a few of the aftermarket stuff as well .
dirtbikekid33 is offline
Old 10-08-2012 | 01:07 PM
  #30252
done with the first diff now. Feels (a bit) tighter than the rear one (<- without good shimming), but without the extrem wobble at the outdrives. I used 0.1 out and 0.4 in at one side and 0.3 out + 0.4 in at the other side. I'll rebuild the rear diff tomorrow.
Cody227 is offline
Old 10-08-2012 | 06:44 PM
  #30253
Cain,
You are a fkn saint. Your patience is rock steady... I was flinching just reading it.
It looks like rain is coming in, my race season might be coming to an end this weekend. Time to decide if i'm spending alot of money in gas to drive up to Wild Choke's place; TRCR, or go carpet touring racing for the winter.
SC Shaun is offline
Old 10-08-2012 | 07:28 PM
  #30254
Cain's Avatar
Tech Legend
How far is the drive up there to that track SC Shaun?
What are peoples thoughts on compounds they are using and tires for carpet with there sc10 4x4?
Cain is offline
Old 10-08-2012 | 07:43 PM
  #30255
CraigMBA's Avatar
Originally Posted by Cain
I would think as you accelerate down the straight, you would want it to be more stable which according to the manual is opposite of what you would see by adding in toe out.
Well...
I have seen a lot of "factory" drivers say "my car wanders, I'm putting toe out into it" and it work. It makes the car track straight because it induces scrub, and the extra toe out makes the car tun in a little crisper. It also can induce a mid corner push because of the ackerman it induces.
Because of the servo's self centering function, toe in (which in a "street" car causes the car to go straight by the same sort of tire scrub) seems like it makes the car have hyper steering center off.
On an unrelated note, after running sedans indoor on carpet for a week, I now realize what a pile of shit 4wd short course is to drive by comparison.
CraigMBA is offline
