Like Tree5Likes
SC10 4x4 Thread
Old 10-25-2012 | 08:27 AM
  #30766
t0p_sh0tta's Avatar
Are there any pics floating around of the Pro drivers' trucks?
t0p_sh0tta is offline
Old 10-25-2012 | 08:30 AM
  #30767
ryanpatrickgore's Avatar
Live rc posted a few from some of the last big races in California. In there photo galleries
ryanpatrickgore is offline
Old 10-25-2012 | 08:37 AM
  #30768
Wild Cherry's Avatar
Also some good pictures of posted on www.rc10.com , review the race reports bout Scotty Ernst Show Down Tour....
Wild Cherry is offline
Old 10-25-2012 | 08:44 AM
  #30769
Cain's Avatar
What day was the report from? went back a few pages but didn't see anything from here:
http://www.teamassociated.com/news/race_results/
Cain is offline
Old 10-25-2012 | 08:59 AM
  #30770
johnbugman's Avatar
Originally Posted by dirtbikekid33
Looking at the diffs the only thing that comes to mind is the brass bushings changed out to steel, but the reason they are brass is something has to wear out and so the bushing is it, replace it with steel and it and the out drive will both wear.
I'm running all aluminium diffs gives it a lil extra weight and very tough too
johnbugman is offline
Old 10-25-2012 | 09:11 AM
  #30771
keddy's Avatar
I've wanted to try those diffs. But never heard any review on them.
Good to know they hold up.
keddy is offline
Old 10-25-2012 | 09:35 AM
  #30772
dirtbikekid33's Avatar
Default Diffs
I haven't seen the aluminum diffs you speak of are the cases aluminum if so I don't know why you would want to add weight to a drive train the lighter the better I would think, as long as it holds up of course.
dirtbikekid33 is offline
Old 10-25-2012 | 09:41 AM
  #30773
Stock diff case wears great , its the .2 shims that are the wearing & the issue ...
Replace .2 shim with the new Ae shim or double up the .2 shim for better wear & tear ...
Old 10-25-2012 | 09:46 AM
  #30774
Cain's Avatar
Only things I could think of to go with the alloy diff cases would be durability and better holding of the fluid assuming case flex is the cause.
Cain is offline
Old 10-25-2012 | 10:19 AM
  #30775
keddy's Avatar
I still love(sarcasm) AE for the fact that they realized there was a problem, updated the part, then didn't tell anyone publicly.
keddy is offline
Old 10-25-2012 | 10:21 AM
  #30776
heavyjeffd's Avatar
I got diff cases from Shaun a long time ago with bearings instead of bushings, they've been great. Tons of run time on them.
heavyjeffd is offline
Old 10-25-2012 | 10:27 AM
  #30777
symmetricon's Avatar
I ran the hotracing aluminum diffs, they are junk. The tolerances were way off.
symmetricon is offline
Old 10-25-2012 | 10:28 AM
  #30778
Cain's Avatar
sad to say it but lots of companies do this. Gotta love running changes. At least with AE if you contact them they will send you the right sized shims for free.
If they made an addendum section on there website specifically about this, it would be great so you could see what the running changes were, as well as updating part numbers too.
Cain is offline
Old 10-25-2012 | 10:46 AM
  #30779
keddy's Avatar
Yeah, forgot about that part. They don't even supply new part numbers. I had to order in a new rear shock tower. Suprise, old style came in.
As for the bearing diff mod. I made some the night I seen the post about them. Even took it a step farther and modified them using a lathe. They were perfect.
Sadly, they failed. The dust at our track is very fine. It gets in bearings bad.
It came to the piont where now I change my diff bearings before every event.
It's the best $4 piece of mind.
keddy is offline
Old 10-25-2012 | 11:20 AM
  #30780
How did u use a lathe for it?
Cody227 is offline
