SC10 4x4 Thread
where is a good place to get lead weight? besides an auto store. Seems like everyint on amain is iron weights.
Also, is anyone here running stick packs with a 550 motor? trying to figure out how much lead I need.
Are you guys putting the 60grams under the spur from maifields setup?
http://www3.towerhobbies.com/cgi-bin...?&I=LXK204&P=7 - Any 'real' Hobby Shop should have this.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCKT0&P=7 - If you're 'that' kind of guy.
Upgrade to the V2, no wobble and more punch. Those two things are the main thing that the revision addressed.
$16 http://www.rcshox.com/sc10cdif-v1-v2-upgrade/
With the Exotek, I put 20 grams on either side of the servo (40 total in front) and left it like that. I think it's excellent but maybe a little more would be better. Not sure just yet
Slight wobble is there when static and moving by hand but once it is under power I don't see lateral movement in mine. Thicker thrust spacer and bearing may have had something to do with reducing the wobble, not sure.
Anyway, $16 and you may be done. Or buy the vts & cover then add the exotek taking more $ out of your pocket. If you don't like it you can get at least $30 out of it in the FS forum and put that money into plan B.
Ok I got the V1 center diff installed right now. I want to switch over to the Exotek front locker and twin garodiscs. Do you think they will be a big difference? The center diff worked great for the first few races but the spur gear wobbles badly and it doesnt seem to have as much low end punch as it use to.. Rx8 and pro 4 4600 13-60 gearing.
Had one too. works great. pretty much the same kind of idea. If you have that and are thinking of the VTS, you probably don't need it.
i have the locker, but i stopped using it. but no c-diff for me so maybe it performs different without. my vts felt a little more consistent without it. if i had no vts it would probably be of more value to me.
thanks for the answers on the exotek chassis guys. i puicked one up for cheap from a guy in here last night less than 1/2 price!. cant wait to try it. ill do a little report next week after i test it.
There is a V2 upgrade kit for the center dif that cures the punch issues. The spur wobbling is because it floats, doesnt effect anything, all ball difs do it.
Tie dental floss fishing line or whatever to the under cover mounts or chassis brace mounts and pick it up with your lipo in.
Balance it left to right by adding weight left of the servo.
You will like the exo, adding weight to the outside of the chassis is better than none, but the exo's weight is more centered and that's where it should be.
I am running 4 pins right now and it seems to be running great. But if I need to adjust for track conditions, under what circumstances would you want more or less pins? Or, put another way, add or remove pins when the truck is doing what?
When you get the new chassis in, pull your weight out and start over.
That's what I was thinking, starting over with the weight placement. That was the process I did first time around.
Cain, thanks for the spring tip but I'm done with that thing. haha
Can't wait to try the hunk of metal! I figure if I don't like it, no big deal as I got a sweet deal on it. Well see tho as my truck is feeling pretty dialed
Can I get a refresher lesson on the pins (I know it's been discussed before, but I can't find where)?
Less pins allows it to "diff out" or send the power to the end with the least traction. Exiting a turn on power shifts the weight to the back and you have less traction in the front. The power will move to the front giving you understeer.
Insert more pins and the power is distributed more evenly front to back and you will have more oversteer.
I run 6 pins most everywhere but will go to 8 on occasion outdoor low bite when the front is not holding the line.
Launching nose up or down? The landing will only be as good as the launch so set up correctly and the rest of the jump will flow.
Losi's usually have an advantage on jumps that are right at the exit of a turn. They put the power down and dont slip. Try more pins to get more drive up the face of the jump. Try 10 then 8 then 6 and see what suits you. Maybe its 7 pins.
(tip for removing pins: push down on one side of the spur and a few pins will pop out, grab it with a needle nose)
There were jumps I had to take a wide line for to build momentum to make, changed to the V2 C-diff on the same layout and I could punch it from a stand still and back side it.
Losi's were holding a tight line and the AE's went wide to make it. You lost a lot of ground if you double singled that section because the backside was into a short straight.
Going wide opened up the door for the losi to turn in on you for a pass.
5Likes
