Palmaris engine thread
#991
someone said my name and here i am...
@stefan: i'm always reading, no reason for edward to pass any information to me...
@topgun: thanks for the nice words, we do our best to kick some butts...
hope the worlds will go as good as our nats and the euros, looking forward to fly to brasil next week.
#992
Originally posted by stefan
Hi Ed,
good to hear that everything is going well for you.
I guess a Picco P/S set would be a great idea, especially since the rod was always Picco's weakest point.
I'm not racing at all right now. My stuff is still in boxes and the weather is going bad here anyways.
I will be racing electric indoors this winter.
Tell Reto and Juergen that I will need engines for next season
Hi Ed,
Reto already answer to you fr your question.
Edward
#993
I hope to meet you at Winternats. Are you comming there?
When LRP engine will hit our markets? I need one for testing.
Edward
#994
Well, got my nickname while I was in the US for the first time (back in 96...).
You know my real name is pronounced a bit wrong in english, it sounds more like rito when a US-guy says it and therefor it wasn't long until "rito the burito" came up...
Not sure about Winternats, would like to but have to check with my boss if this is possible. Maybe...
#995
Hi Edward,
Just brought a Rody rb v12 5 ports from a fellow racer, Actually it is a team one !! I am going to run it as normal and the slip in a new BRB set !!!. JP fx 01 are ok, nothing great about them, was running one a couple of week ago, and the average lap time was 14.37, but with the Rody RB C5 in the same car, the lap time was 14.09 !!!! The Jp looks quicker ( i thought it was quicker ) but lap time never lie!!!! Maybe the JP was wheel spinning, hence got to change 1st gear. My BRB NSR 12 still locks up at TDC !!! never had a engine that do that after 8 litres !!!
cya
philip
cya
philip
#996
Originally posted by xtreme888
Hi Edward,
cya
philip
Hi Edward,
cya
philip
Thanks for update. I agree with you about JPs. They screem a lot, but speed isn't the best. We were able to compare here in LA and it is not quicker in our case too.
Usualy it takes 2 and half gallons beofre our piston material start getting loose. I still have prototype PS12 with 6 gallons throught it and still stacking little bit on TDC.
Best regards
Edward
#998
Originally posted by bbntc3
I have a Mugen MT with BRB design and after 3 gallons of 30% fuel they still stack at TDC. Great work Edward!!!!!! Bob
#1000
While the piston sticking at TDC all the time shows a good sign, it can be time wasting also when you need to restart the engine.
#1001
Originally posted by InitialD
Edward, what would you suggest on how to run in the BRB piston / sleeve set then?
Piston getting stock at TDC only if you turning it slow, if you turning it fast ( starter box) - it will not got stiking.
I always sugest only one procedure to run in-one tanks reach at starter box with temp around 190 F and 2 tanks around the track reach. Then it is ready to lean to race and ready to race.
Due to the our tapering in sleeve and piston friction properties,you will not have problem with start up ( nobody so far had).
One most important thing is-don't look for 220 F running temperature. The normal temperature there-whatever engine will run, as long as it is performing. For sure it will not perform at 200, it like to be run hot.
There was couple times, when engines was overheated ( 325 F) and never ever something happennig to any parts. We are testing new stuff at 300+ for numerouse numbers of tanks.
As I sad before, our tapering and materials came from airmodeling and boating and in some classes in airmodeling start is one of the most critical issue-you miss start engine first time-you loose competitions. Ther are at list 3 landing and refill during the qualifying with engine off. And it is Diesel, not glow engine-very tight type with much higher compression then we have in RC cars.
#1003
Originally posted by kevink2
Edward your PM box is full... FYI, if it's filling up quickly I just found out that we have to clean out our "sent messages" too. Doh!
#1004
Hi Edward,
Managed to get down the track today, ran the RB V12 5 ports Rody.......this thing is crazy !!!! As you are aware that i races 1/8th as well, the speed on this engine is amazing..............sooooooo much power.....was overtaking other drivers with novamax, jp and sirio evo 2 as well ( i could take them anywhere i like !!!)...,..even some of the 1/8th suffer from overtaking !!!! Ended up with solid axle and front one way like the eighth.....with a diff the car was undrivable coz the engine was too powerful........wonder what a brb set be like ????????.
The engine was quicker than my JP FX 01 in the eighth, but my RODY C5 is nothing like this....why there is no bottom end like the 1/10th version ?
Philip
Philip
#1005
1Likes
