Losi 1/8 8ight E 4wd Thread
#8028
How do u like that eb48 compared to the losi??? But yes I just can't see getting rid of them and I will be going nitro also.
#8029
Does anyone know if the new Proline bulldog...
http://prolineracing.com/bodies/2012...r-body-8ight2/
or the new JConcepts Punnisher...
http://www.jconcepts.net/store/index...roducts_id=399
will fit on the 2.0e and clear the big 4s pack? Thanks!
#8031
I run tekin motor and tekin rx8 no issues. Running on 4s. Only problem i bought a 2250 kv way to Much motor. I didn't know at the time. I use it turned way down can make 15min main with 4s 5000 pack.
#8032
I use a Tekin RX8 as well with a T8 1700kv motor. It works great for smaller tracks and has plenty of power on a 4S lipo. If you run on a larger track, try a 1900kv motor. If you go with the 1700kv motor try 16/44 for gearing on the 8E.
#8033
I'm running the RX8/Tekin 1900KV setup on a 1/10 track that hard packed and gets dry and abrasive fast, especially in this heat. I'm burning through tires fast and wonder what most of you would use for a current limiter setting in this situation. I have mine at 80. There is an area where you have little room to get up speed to clear a triple so I need good punch but still think wheelspin may be adding to my fast tire wear. I am talking about 40 minutes and my soft compound tires are pretty much done.
#8034
I have an old 8ight 1.0, just got the Tekno conversion and a 2.0 rear drive shaft to make a 1.5, are many running this setup?
#8037
Does anyone know if the new Proline bulldog body will fit my new TLR 2.0e...
Thanks for any info!!!!
#8039
#8040
