Losi 1/8 8ight E 4wd Thread >
Old 08-29-2012 | 01:58 PM
  #8056
tmo420's Avatar
Ya that Tekin will flame up if no repaired correctly.
tmo420 is offline
Old 08-29-2012 | 02:02 PM
  #8057
tmo420's Avatar
LOSA1754 I believe this is what u are looking for.
tmo420 is offline
Old 08-29-2012 | 06:07 PM
  #8058
dangerwr's Avatar
Originally Posted by D.a.v.e
I'm sure someone listed them somewhere but I've not yet found it.. I'm looking for the hop up part numbers required for the Drake setup.
Does buying the adjustable front pivots add any benefit if they are set to 0 in the setup? Thinking I could skip this for now?
Smart man. Skip those altogether as they are a liability in my opinion. Using those up front creates a weak spot on this buggy. Same setup as the stock stuff if running 0's all around. If you take a hit with the front the hinge pin will rip out of these adjustable hinge pin braces and ruin them. The 1.0 versions were a better design in my opinion. Much easier to "spit" a pin with these adjustables with the plastic inserts over the stock braces.
Here is a good rule of thumb I use; unless you can run a carbon front shock tower do not use these! This simply means that you do not wreck hard and your buddies know how to drive. Cheers!
dangerwr is offline
Old 08-29-2012 | 06:39 PM
  #8059
goehm's Avatar
Originally Posted by NITROALM
Thank you Will for the info++
Also Here is a pic from one of our guys ...Looks Great
I just got my BCE and got it put together. Question for ya tho since you're here!
My kit came with a washer to raise the motor mount/diff a little off the chassis so the center gear doesn't hit. Threw me for a loop because the gear kept rubbing and binding. Turns out that the washers are wide enough such that it sticks out past the mount and rubs the gear. Essentially it eliminates any of the machined pocket below the gear. I thought it was hitting the chassis, but after I realized it was hitting the washer I dremeled it and all is good.
I was wondering if anyone else reported that issue? Seems like narrower washers are the key, so I'm keeping my eye out for some.
It does NOT rub on the metal gears since those are spaced out from the motor plate side, but the plastic ones have wider gears and sit real snug against the motor plate.
Thanks,
GO
goehm is offline
Old 08-29-2012 | 08:35 PM
  #8060
tmo420's Avatar
I run them and never " spit" one yet. I like the adjustability though. To each his own though.
tmo420 is offline
Old 08-30-2012 | 06:16 AM
  #8061
D.a.v.e's Avatar
For the SCTE they came out with longer hing pins to compensate for the larger angles created by using these. Have they done the same for the eight?
D.a.v.e is offline
Old 08-30-2012 | 11:13 AM
  #8062
Any here try putting shims between the wheel hex and bearing to remove some slop in the wheel? I think 8mm shims would work.
jha07 is offline
Old 08-30-2012 | 07:26 PM
  #8063
Integra's Avatar
Yes, Kyosho sells a .1 .2 .3 kit that works the ticket.....BUT be very careful as to How much you shim. If you go too tight you'll blow bearing's left right and center. There's an Acceptable amount of slop that Needs to be there for thing's to function properly.
Integra is offline
Old 08-30-2012 | 10:06 PM
  #8064
dangerwr's Avatar
Thanks,
GO
Mine were the right size so that the plastic spur did not rub but had a helluva time getting the screws to fit through the I.D.!!
dangerwr is offline
Old 08-30-2012 | 10:48 PM
  #8065
Thanks for the tip.
jha07 is offline
Old 08-30-2012 | 11:15 PM
  #8066
NITROALM's Avatar
Thumbs up
Thanks,
GO
Hi Go:.. Yes we have been trying to find the perfect spacer,
but as you and Will have mentioned, we have a nice small one
but the ID is a pita to get the screw through, and the large
will rub on the plastic gears your way of grinding the edge off
is great.. it will allow good clearance for both gears. Also a little tip is once
you get yours set up, just put a little spec of CA and they will stay right
in place.. Thanks for your guys input.. keep us posted on you track/Racing
updates
NITROALM is offline
Old 08-31-2012 | 05:57 AM
  #8067
goehm's Avatar
Thanks! I'll get a pic up soon. Car ran best it has all season. Admittedly I'm not the best 1/8 driver, but I managed to qual 4th at our ROAR event with the chassis. I'm really impressed, great job.
As a side note, I'm going to start a quest for that perfect spacer. If I find something that works really well for me I'll share.
I'm thinking something like this:
http://www.exotekracing.com/22-22sct...ranny-spacers/
Father in law works at a machine shop. If I can get his ear I was actually thinking of creating basically a single piece hard gasket of sorts to give a nice fit that would be really easy to work with/install
goehm is offline
Old 08-31-2012 | 06:11 AM
  #8068
I've got to ask...
Tekno v4 or BCE chassis?
I searched and only found comparisons between Tekno and Losi. Between those two I like how the Tekno sounds but the BCE is about the same price so it's an option...
My 8ight that I picked up used could use a new chassis and right low I'm leaning toward the Tekno because it gives me the option for mechanical brakes, lower cg (compared to Losi conversion, and comes with more stuff so I feel like in getting more for my money haha.
iTz Nicholas72 is offline
Old 08-31-2012 | 07:10 AM
  #8069
Integra's Avatar
Losi where its at, Mechanical brakes are Not needed what so ever Nor does the Standard "E" layout need to e changed.
Integra is offline
Old 08-31-2012 | 03:26 PM
  #8070
dangerwr's Avatar
If I have some extra time (not likely) I can punch something out in CAD and print it on our high-end 3D printer (material is like ABS). The link you sent would be an ideal solution and is what I could use to model up for the 8ight. As an alternative an expensive mold a waterjet could be used to cut these parts outta a sheet of CF.
dangerwr is offline
