Losi 1/8 8ight E 4wd Thread >
Old 10-22-2012, 08:16 AM
  #8176
JC1225's Avatar
I was just wondering... Is it possible to convert one of these 8E's to nitro.
I haven't heard of anyone doing this. Is it not practical or not possible?
JC1225 is offline
Old 10-22-2012, 08:24 AM
  #8177
chucko's Avatar
Originally Posted by Hotbodiesd4 View Post
Does anyone else's car have huge belly slap off big jumps? is it normal?
if your jumping yes that does happen. and it does hurt electronics
you could try to gas it in air to bring the nose up then gas it just when it hits or use thicker oils in the shocks or slow down on that jump unless your the bank and have a bunch of parts and dont care about your ride. I know in the moment its fun to fly. but rebuilding can be a pain when your racing and need to go 1 more race and your chassis is bent or have broken arms and shocks. I have done it. its cool. but it costs to have fun...
chucko is offline
Old 10-22-2012, 08:26 AM
  #8178
chucko's Avatar
Yes the chassis is drilled for it. different parts and it will work
chucko is offline
Old 10-22-2012, 10:42 AM
  #8179
immarcescibile's Avatar
Hi guys
Can anyone give me some advise on fitting a pinion gear?
My pinion keeps coming off.
In the manual it doesn't say that you have to use thread lock, but I have tried it and it still comes off.
Could it be that my gear mesh is not right?
Thanks in advance for your input.
The problem is the "hex shape": if you use a flat shape that tightens "flat" on the shaft it will not produce enough fixing force.
You have to use a pointy hex, in this case it will fix better and the pinion will stay there.
This is how I came across the issue.
immarcescibile is offline
Old 10-23-2012, 08:38 AM
  #8180
JC1225's Avatar
Thanks gentlemen...
JC1225 is offline
Old 10-23-2012, 12:41 PM
  #8181
Old 10-24-2012, 09:12 PM
  #8182
I have got 40 weight in it atm and the car is still saggy???
Hotbodiesd4 is offline
Old 10-26-2012, 06:45 PM
  #8183
Default Indoor carpet setup
Does anyone know where to find a good indoor high bite carpet setup, thanks
Crispybacon is offline
Old 10-29-2012, 06:22 PM
  #8184
rcguy76559's Avatar
Trader Rating: 22 (100%+)
ackerman short vs long do you get more steering or turn in on short vs long.
rcguy76559 is offline
Old 10-29-2012, 08:53 PM
  #8185
drepus's Avatar
Short gives more turn in. Long gives a smoother turn in with more mid and exit.
drepus is offline
Old 10-30-2012, 06:59 AM
  #8186
rcguy76559's Avatar
I just switched to the 10 inclined setup but have not ran it yet like that. I also have the 12* carriers to. I run on med size track 30sec laps fast guys. is pretty tight. So would I be better off to switch to short then. So short will make both wheels more angled from one another?
Old 10-30-2012, 07:17 AM
  #8187
mikesd1980's Avatar
Trader Rating: 76 (100%+)
What do you mean? A E buggy is a nitro buggy with a E conversion. It can be converted back if you buy the parts. ie...engine mounts, gas tank, radio tray, exhaust pipe holder and whatever else I may have missed.
mikesd1980 is offline
Old 10-30-2012, 07:29 AM
  #8188
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Not worth it in my opinion, unless you've ran nitro before and liked it. All i can say is there is alot more things to go wrong with nitro. Plus you won't have that instant power of electric.
Rockthecatbox21 is offline
Old 10-30-2012, 08:06 AM
  #8189
drepus's Avatar
I find the ackerman link is a personnel preference thing. If you need more initial steering then i run the short one. If you want a smoother turn in run the longer one.
For me the inclined front end has a smoother turn in with more mid corner and exit steering than the standard front end. I now always use the 10 degree inclined front end unless the track is either very low grip in the slow speed sections causing a lack of initial steering grip or if the track is very tight with lots of low speed corner sections like an indoor track. The 12 degree inclined blocks help reduce initial turn in on very high speed & grip tracks. The 12 degree blocks will give more exit steering.
Spend some time on a prsctice day and test the two ackerman plates back to back then try the inclined front end vs the standard so you can learn what it does to the way it makes your car handle.
drepus is offline
Old 10-30-2012, 09:15 AM
  #8190
rcguy76559's Avatar
thanks for all the help! Their only few losi here and the fast guys hardly show up with theirs. I do know they run 10 inclined setup. Not sure on ackerman tho. Thanks again for the help
